Ender 3 s1 pro 'mcu errror'
Printer Model: Ender 3 s1 pro
MCU / Printerboard: STM32F401
Host / SBC Pi 3 B+ using mainsail /klipper
Hi all I’ve been trying to get klipper to work with my ender 3, i’m pretty sure its possible :man_shrugging:. So far I’ve got the pi board connected to the ender 3 via usb a → usb c.
I made the klipper.bin file using the following settings in the menuconfig
I’ve made a partition on my sd card with fat32, made a folder as ‘STM32F4_UPDATE’ and placed the bin file. Take the sd card and place it into the ender 3 power on, the screen does not load correct which from what i’ve read is normal. After a bit the screen goes black, i assume at this point the flash is done, and power off the ender 3.
reboot/ restart everything log into my pi board via the web to get to the mainsail dashboard, I get the following.
Klipper reports: ERROR
mcu ‘mcu’: Unable to connect
Error configuring printer
I’ve tried what i feel like is everything to get the two to talk to each other , any help will be greatly appreciated.
printer.cfg.txt (2.8 KB)
klippy (1).log (893.4 KB)
Is this what you see with running:
ls -lta /dev/serial/by-id/*
in an ssh session? or if your using KIAUH you can choose 4) Advanced menu, 5) get mcu id
Yes that is what i am getting when running cd /dev/serial/by-id/* via ssh
my printer is currently running a print but i can post a screen shot in a few.
WindowsTerminal_Y9mkGKZHaY
Have you read this one?
in there I read
Aug 2023
fixed
@cbrew
Your error is:
mcu 'mcu': Unable to open serial port: [Errno 2] could not open port /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0'
Check Debian Bullseye Bug causing Klipper to no longer find the printer board 54
It leads to this one..
hope its that easy, alot of us users fell into the rights bug
on the Klipper discord they had pinned a script that did all the fixes. its pinned in the mainsail forum on klipper discord.
Fix for current by-id issue in debian updates
curl -sSL https://raw.githubusercontent.com/mainsail-crew/MainsailOS/develop/patches/udev-fix.sh | bash
I dont know if any of this is your issue, but like I said earlier. a bunch of us got hit with it.
I have looked into Sineos fixes, I ran the diagnose and my udev was:
This is not the ‘deb11u2’ as outlined in his post.
let me know what else can help diagnose this.
(sorry for the janky screen, i can only post on at a time :roll_eyes:
Thank you :slight_smile:
Was hoping, but I guess I’ll have to defer to others here. was reminded earlier tonight, with a warm welcome; that I should let the pro’s support folks on here. Hope you well.
I saw this one as well… with double checking the processor/comm port btw
@DaVinci10 answers point into the right direction.
It is mandatory that you properly identify the MCU on this board and then use the correct settings.
Also the SD card used for flashing can make a big difference.
Generally, see Issues flashing the printer board for the influencing factors and what to check.
pics.zip (4.3 MB)
I’ve added a zip folder of a few pictures, 1: the mcu, 2: the micro sd card I am using) 3: the formatted partition of the micro sd card.
Not sure if this qualifies as a “good quality” sd card. From that link you’re guessing the sd card or cable? Is the a good way to know if the mcu is flashing correctly without a proper screen?
Thank you.
I will say I did use the same card to flash the mcu back to crealitys firmware.
There are a lot more items mentioned in this link. It is quite impossible to say which is the root cause from remote.
I propose to systematically go through them in the order they are listed.
I wouldn’t be opposed to you remoting into my system, I think the biggest hurdle would be time zones.
make menuconfig Settings
I’ve posted the settings and mcu within my printer.
Flashing the board
I’m flashing via a sd card and have posted my procedure.
The SD Card used for flashing
This question was never answered and posted all of what I have performed.
USB Cable / Connection
I would assume that if the pi board is seeing the serial, it is a ‘good quality’ cable.
Linux Issues
I’ve posted the ‘common’ linux issues and do not think my pi has these issues, and even preformed the ‘fixes’
Obtaining the board’s serial
The only thing that I see here is its possible that the serial might change, how common is this?
  • For the F401 MCU your settings seem correct
  • I cannot speak for the quality of your USB cable
  • The guide above clearly mentions a SD of below 8 GB for flashing and I cannot comment on the quality of yours (not saying that it has to be the root cause)
  • The board has CH3xx USB chip, so it will always register as /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 (regardless if Klipper is correctly flashed or not)
From the instructions
# Flash this firmware by copying "out/klipper.bin" to a SD card and
# turning on the printer with the card inserted. The filename
# must be changed to "firmware.bin"
# With STM32F401, you might need to put "firmware.bin" in a
# folder on the SD card called "STM32F4_UPDATE" in order to flash.
  • It seems not clear with this board if STM32F4_UPDATE is needed or not
  • There are reports that renaming the klipper.bin to firmware.bin might not be working
  • A lot of the Creality boards require changing the firmware filename on every flash attempt
I do not own this board, so I cannot comment first hand. There are enough reports that it works, so it is likely something on your end.
Follow the dmesg instructions that are equally outlined in the link and check if there is anything telling.
I appreciate all the help. When I downloaded the firmware from creality it did have the STMF4_UPDATE folder, I forget the name of the file.bin,.but maybe I can just try copying over the klipper.bin and renaming it, I think thats the only thing I haven’t tried. Would you think re-formatting to 8gb would suffice or just getting a 8gb card?
dmesg.txt (35.2 KB)
This issue was fixed via discord with James. you can format a large sd card, i did mine for 8gb, and was able to flash successfully.
