Ender 3 s1 can't connect to MCU
Ender 3 s1
STM32F401
Raspberry pi 2w
klippy-2.log (170.1 KB)
I am using an ender 3 s1 with rpi 2 w.
ls /dev/serial/by-id/* gives /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
Using an 4096, FAT32, 8gb SD card, with firmware.bin in a folder named STM32F4_UPDATE
I am using the config settings mentioned in the .cfg files (like 64kb bootloader or 8mhz crystal)
Please help.
Hello. Are you sure you are using Q to exit and Y to save after making the changes to the menuconfig? I ask because according to your klippy.log the values were not set on your last build.
Also if that doesn’t help, try NOT changing the name to firmware.bin, leave it as klipper.bin. I’ve seen some reports of it working that way.
I tryed and it still isnt working. FYI I have a s1 not pro
It’s all the same, pro/plus/regular. Are you sure you have the F401 mcu?
Just spotted your problem. Remove the = on your MCU line.
Screenshot 2024-12-18 at 5.53.37 PM
never had =
Are you sure? Cause this is the klippy.log you posted. Can you post a fresh klippy.log?
so while i was waiting i did the steps in the tutorial u sent so i will redo on weekend.
Klipper accepts both the : and = for settings. The common convention is to use the colon in the configs, but after parsing in the klippy.log, they are turned into equal signs.
The error messages indicate either:
  • Connection issues between board and host
  • MCU not flashed properly
These boards seem problematic. Apparently some require this folder, others might not.
I am going to get a Smartprintcoreh7x and then use that
Interesting board. Never heard of it and I absolutely compliment them for their OSS policy.
Just two comments:
  • It is a massive overkill for an Ender 3
  • There are proven and much cheaper boards out there
But go ahead and report back. :+1:
What other boards would be better?
Better is always relative and assumes this board might be bad.
Suitable alternatives are:
  • BTT SKR MINI E3 V3.0
  • Fysetc S6
  • BTT Manta M5P
To list just 3 popular boards.
