Jakez
October 7, 2023, 3:56pm
1
Printer Model: Ender 3 S1 plus
MCU / Printerboard: CR-FDM-v24S1_301 or 2.0.8.26F4
klippy(6).log (963.5 KB)
I tried all the possible solutions
reboot pi4B and printer
jakez@Ender3S1:~ $ ls /dev/serial/by-id
usb-1a86_USB_Serial-if00-port0
debian
raspberry pi lmager 64 bit
Sineos
October 7, 2023, 4:55pm
2
Make sure you are building for the correct MCU type. Closely read and check the header information here: https://github.com/Klipper3d/klipper/blob/master/config/printer-creality-ender3-s1-2021.cfg
Jakez
October 8, 2023, 4:44am
3
my printer is plus version
printer cfg
This file contains pin mappings for the stock 2022 Creality Ender 3
S1 Plus. To use this config check the STM32 Chip on the Mainboard,
during “make menuconfig” select accordingly either the
STM32F103 with “28KiB bootloader” or the STM32F401 with
“64KiB bootloader” and serial (on USART1 PA10/PA9) for both.
For a direct serial connection, in “make menuconfig” select
“Enable extra low-level configuration options” and Serial
(on USART2 PA3/PA2), which is on the 10 pin IDC cable used
for the LCD module as follows: 3: Tx, 4: Rx, 9: GND, 10: VCC
Flash this firmware by copying “out/klipper.bin” to a SD card and
turning on the printer with the card inserted. The filename
must be changed to “firmware.bin”
With STM32F401, you might need to put “firmware.bin” in a
folder on the SD card called “STM32F4_UPDATE” in order to flash.
See docs/Config_Reference.md for a description of parameters.
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
rotation_distance: 40
endstop_pin: !PA5
position_endstop: -10
position_max: 316
position_min: -15
homing_speed: 50
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
endstop_pin: !PA6
position_max: 304
position_min: -15
homing_speed: 50
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
rotation_distance: 8
position_max: 300
position_min: -4
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
gear_ratio: 42:12
rotation_distance: 26.359
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
pid_Kp: 23.561
pid_Ki: 1.208
pid_Kd: 114.859
min_temp: 0
max_temp: 260
[heater_bed]
heater_pin: PA7
sensor_pin: PC4
control: pid
pid_Kp: 71.867
pid_Ki: 1.536
pid_Kd: 840.843
min_temp: 0
max_temp: 100
[heater_fan hotend_fan]
pin: PC0
[fan]
pin: PA0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 2000
max_z_velocity: 5
max_z_accel: 100
[bltouch]
sensor_pin: ^PC14
control_pin: PC13
x_offset: -31.8
y_offset: -40.5
z_offset: 0
probe_with_touch_mode: true
stow_on_each_sample: false
[bed_mesh]
speed: 120
mesh_min: 20, 20
mesh_max: 283, 263
probe_count: 4,4
algorithm: bicubic
[safe_z_home]
home_xy_position: 187, 192
speed: 75
z_hop: 10
z_hop_speed: 5
[filament_switch_sensor e0_sensor]
switch_pin: !PC15
pause_on_runout: true
runout_gcode: PAUSE
[pause_resume]
recover_velocity: 25
Sineos
October 8, 2023, 3:48pm
4
Jakez
October 8, 2023, 5:15pm
7
Thankyou the problem is solved!
I am not sure how to close this
