Calibration prints
Printer Model: Mendel90
MCU / Printerboard:BTT Manta 8P/CB1/ TMC2209 drivers
Describe your issue: Source or recommendation of Calibration prints and/or proceedures.
As I bring this beast back to working I wonder if there is a guide to which prints will help me with setting the various parameters for extrusion. Extrusion Factor, Feed Rate and where to start. I have an E3D V6, .4 mm nozzle fed by a Wade’s geared extruder. Current settings are the default install.
Teaching Tech 3D Printer Site (teachingtechyt.github.io)
This site is pretty comprehensive…
My Calibration sequence is:
-General Items check:
  •    Bolts and Nuts
  • V-Roller
  • Lead screws
  • Bowden Tube
  • Hotend
  • Extruder
  • Belts
  • Fans
  • Firmware
-Acceleration Calibration:
  •    Test Accelerometer (if applicable)
  • Calibrate Input Shaper
  • Calibrate maximum acceleration
-XYZ Calibration:
  •   X-Axis steps
  • Y-Axis steps
  • Z-Axis steps
-PID Tune:
  •   Hotend
  • Bed
-First Layer:
  • 	X-Axis Gantry Tilt
  • Probe X and Y Offset
  • Manual Bed leveling
  • Probe Z Offset
  • Auto Bed leveling
  • Test print Bed leveling
-Extruder Calibration:
  • 	E steps
  • Slicer flow
-Temperature, Retraction and Pressure advance Calibration:
  •    Temperature Tower
  • Retraction Tower
  • Pressure advance Tower
Hope that helps.
Cheers
Florian
Thank you for that link. A brief look and it seems he covers ‘EVERYTHING’ ! I will be following a lot of that program as it is well laid out with lots of supporting docs.
