Save Zoffset between print jobs
Printer Model: RatRig Vcore 31
MCU / Printerboard: Octopus Pro
klippy.log not necessary
Its not a issue..
I have searched for this question in the forum but I have not found it, I suppose it will be resolved… sorry for repeating.
When I start a print, I adjust the ZOffest while the printer does the SKIRT…, and I have to repeat this procedure each time.
I know that in Fluidd, when printing is finished you can save this adjusted Offset, but I rarely remember to do it…
It can, I suppose so. Although the best asked question would be.
  • How do you save the Zoffset adjusted in a print so that it is used in the next one by default?
I had thought about END MACRO, including the order to save it… but… How?
You can save Z_offset with Z_OFFSET_APPLY_PROBE.
But you have to do a SAVE_CONFIG after that to keep it stored.
With that, there should be no need to do the adjustment every time.
I will try next print
Thanks
