Z - offset resets after each prints
Hello, i am having an issue with my z offset. My offset is saved in my printer.cfg under [prtouch_v2] z_offset. The issue is that each time i start my printer the first print is fine because it uses that z offset but when i launch a second print the z-offset is way off. What i found out is that after each print there is a line in the console saying z offset = 0. Then i see the z offset on the left the negative value of my desired offset (see image) and it will stay like that for all the remaining prints. I cannot for the life of me figure this one out.
Printer : Rooted Creality K1C using Fluidd
Packages installed : KAMP and improved shapers
Slicer : Orca
klippy.zip (3.7 MB)
Hello @Scienceaddict !
For a genuine Klipper I would say: The offset is stored in the SAVE_CONFIG block at the end of the config file.
But in this case:
:man_shrugging:
We do not know what Creality has done to the code.
