Klipper delta bed mesh/ z height issues
Printer Model: Flsun Super Racer
MCU / Printerboard: Mks Robin Nano V3
klippy (4).zip (1.1 MB)
Describe your issue: when setting z height offset either on Klipperscreen or fluiddpi during printing i can adjust the layer to correct height but for some reason klipper either doesnt save it correctly or isnt using it i adjust the height to a correct one then after finishing the print and saving new z height and rebooting when starting the next print it either is completely touching bed or only a vary small distance from it. I tried releving multiple time its a delta so there is no adjustment on the bed but according to the probe which accuracy checked out great is showing a larger variation on the bed mesh but i know its not that far out i have checked it multiple times its glass so and of all things when using marlin it printed perfect i just wanted the better accuracy and consistency with klipper. but the printer was printing great before the switch and now its like is doesnt save adjustments made to z height or has issues on each layer
