Printer Model: Fl Sun Super Racer
MCU / Printerboard: Robin_nano_v3
I was struggling with the printer running the print head into the bed after i would bed level and z height no matter what i did it would hit. I learned that You MUST SET Z HEIGHT FIRST then run bed level or the head will hit the bed. Maybe just in my case but wanted to pass it forward.
