Printer prints in the air
Printer Model: FLSun SUperRacer
MCU / Printerboard: SKR 1.3 clone
klippy.zip (150.5 KB)
Just updated Klipper to current status. Verified good Z=0 by paper test, then repeated G1 Z0 to ensure printer knew where Z=0 is. First print started with nozzle about 25 mm up from printbed. After that G1 Z0 puts nozzle about 25 mm up from printbed.
Link to my printer.cfg: printer.cfg - Pastebin.com
Printer.cfg has this line in the [probe] section:
#z_offset: 13.0
and this line in the ## [probe] section:
# z_offset = 0.010
I’ve tried doing PROBE_CALIBRATE, MANUAL_PROBE, Z_ENDSTOP_CALIBRATE, but none of them fix my problem.
You need to run DELTA_CALIBRATE to adjust Z0 on a delta. Since you don’t have a calibrated probe offset, I would suggest doing the manual method.
I did run DELTA_CALIBRATE prior to my latest update to the current Klipper version and I still had the same problem. But I’ll run it again now. I have also done both the auto and manual Z0 functions, but I’ll redo those also. Will post results later today.
Your suggest enabled me to solve my problem - sort of. This is the sequence of commands and events that led to a good solution:
Power on
Home
Probe_CALIBRATE followed by manual Z0 adjustment
ACCEPT
SAVE_CONFIG
Home
DELTA_CALIBRATE
SAVE_CONFIG
home
G1 Z50
G1 Z20
G1 Z5
G1 Z2
G1 Z0 <== Nozzle tip was maybe 0.5 mm above a good Z0 value
MANUAL_PROBE
Manual Probe -0.01 eight times to get to a good paper test value
ACCEPT
SAVE_CONFIG
Home
Reboot
Start test print
Print started in mid-air about 30 mm above print bed
Since I think creating a bed mesh has something to do with how Klipper establishes the Z0 offset I deleted the mesh I had previously created (which looked quite good actually), and ran
SAVE_CONFIG
Home
Verified there was no stored mesh
BED_MESH_CALIBRATE
Accept
Home
SAVE_CONFIG
verify new bed mesh was created ok
Start test print
This started printing very close to the printbed, but the nozzle was too high. I used the baby-step adjuster to get the nozzle down to a good printing elevation. Then I cancelled the print followed by a Save Z-Probe and SAVE_CONFIG just to be sure.
I appreciate your suggestion to do the DELTA_CALIBRATE command - I didn’t do that because I thought the delta calibration values (whatever they are) were stored in printer EEPROM (I used to use Marlin), but this is clearly incorrect. I do suggest the Klipper documentation for delta printers be updated to include the above command sequence so that other people don’t fall down the same rabbit hole I did.
Klipper has pretty extensive documentation on the proper way to calibrate a delta printer. It’s not clear to me that the method you used will result in accurate prints.
https://www.klipper3d.org/Delta_Calibrate.html
I’ve read that page several times. My point was it’s the entire sequence of events that allows the printer to work, and I think I’m not the only one who didn’t get an understanding of what the sequence needs to be. And as far as accuracy goes, this is good enough for me:
