Z in mid air at start..Fails to lower
Ender 3 Pro
4.2.2
RPi3b
klippy.zip (154.0 KB)
As a Klipper newbie I really feel bad about posting this after reading so much for so long I really can not identify why I’m so thick and failing to get my nozzle close to the bed using the correct z_offset. Ive watched and tried so many YT clips along with following Klippers own documentation on probe_calibrate & calibrating probe z offset all to no avail. When ever I start a print the nozzle always stays around 3 to 4mm away from the bed.
Id really really appreciate some hand holding & baby talk here please..
Have you already done this: Probe calibration - Klipper documentation
And you may delete line 8 here:
[gcode_macro START_PRINT]
gcode =
	{% set BED_TEMP = params.BED_TEMP|default(80)|float %}
	{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(245)|float %}
	M140 S{BED_TEMP}
	G90
	G28
	SET_GCODE_OFFSET Z=1.0
	M190 S{BED_TEMP}
	M109 S{EXTRUDER_TEMP}
I am assuming you mean adjust line 8 ! If so yes. Also yes to the Calibrating probe Z offset in the Klipper docs..
May delete it .. Ah OK will try that
No.
If you done the calibration properly, the actual offset is stored in the printer.cfg. There is no need to change that.
The offset I require is stored at the bottom of the printer.cfg file. So may I ask should I comment out that line 8 ? thanks
Well that’s interesting. I commented out line 8 and all seems good. You nailed it thank you for your help..
Well I spoke too soon. Worked once, shut down had lunch and still the same issue next time I’ve switched it on FFS!!
Please attach a recent klippy.log to your next post.
Thank you.. Me trying to just comment out for some reason did not work but deleting as you suggested has. Thank you
