My z_offset=X no matter what number of the X is, it doesn’t effect
but use the probe command, I can put the correct value after the Z_offset result and save the value
but it doesn’t develop nozzle while printing
But.I use one of the macro (START_PRINT) , change the “SET_GCODE_OFFSET Z= (correct value)” to run the macro “START_PRINT”, the nozzle develops correctly, but I have to change the (correct value) time by time manually when I use the probe command
I hope to use a way like “SET_GCODE_OFFSET=probe.z_offset” to update the value of the Z_offset.
I know that the coding way of “probe.z_offset” is not correct
please tell me how to quote the Z_OFFSET pf the [probe] and give me some MACRO examples
I’m not sure I understand.
The probe’s z-offset is tuned once and then usually left like it is. It is always active and determines the bed’s Z origin after homing.
If you need further correction one would use SET_GCODE_OFFSET
Could you explain how you implemented your printer and the three Z axis joints (as it’s a delta printer)?
I had a similar problem on one of my printers until I put in anti-backlash nuts on the Z axis lead screws - there was enough resistance that gravity wasn’t enough to keep the Z axis nuts at the bottom of the threads.
“z_offset:X” X will be updated but this updated value is useless
I used to fix the value to 10 but the Z was not raised
So I can only fix it with SET_GCODE_OFFSET
