Klipper Z axis issue
Printer Model: Ender 3 V3 SE
MCU / Printerboard: MS35774
qt.log (96.3 KB)
… After installing Klipper on my Ender 3 v3 SE and running through Ellis’ tuning guide I noticed that no matter if I do my Z offset automatically or through the calibrate probe command and doing a bedmesh, my first layer is too inconsistent. Some parts of the print will lay down perfect and others will be printed too high. Also as the print gets taller you can hear the nozzle start to drag. Reflashing back to stock firmware makes it print perfect again. I’ve reflashed Klipper since then trying to get this to work, but no matter how I tune it the problem persists.
Hello @Draycon !
The log you provided is no klippy.log.
please attach the klippy.log to your next post.
Printer Model: Proforge 3.5
MCU / Printer board BTT SKR2
klippy (2).log.zip (1.1 MB)
I upgraded my Klipper system two days ago:
crowsnest
v4.1.6-1-ge96cd46
UP-TO-DATE
klipper
v0.12.0-132-ge37b007f
UP-TO-DATE
mainsail
v2.10.0
UP-TO-DATE
mainsail-config
v1.2.1-0-ge57810d5
UP-TO-DATE
moonraker
v0.8.0-324-ga3e4dac5
UP-TO-DATE
sonar
v0.1.3-1-geacc498a
UP-TO-DATE
System
OS-Packages
My Probe z_offset is not saving anymore.
I have tried the Z Calibrate routine in the Pi LCD display and manually adjusting the Z Offset in the Mainsail.local UI.
I notice that the [Probe] z_offset parameter is commented out in Printer.cfg.
Where is it stored?
Thanks.
@SaltyDoug !
Why do you hijack another one’s thread?
