Z Offset. Im going CRAZY!
Printer Model: Ender 3v2
MCU / Printerboard: 4.2.2
Host / SBC: Pi 4
klippy.log (3.7 MB)
Hey guys, noob here
For the life of me I cant fiqure out what Im doing wrong. Ive read the Docs, guides, watched videos. It just doesnt play ball.
I have run the PROBE_CALIBRATE command (BLTOUCH) and dialed the head down using paper as my gauge. Accept the prompt and save the config. It restarts and I get
Klipper reports: ERROR
Option ‘z_offset’ in section ‘bltouch’ must be specified
Printer is halted.
The few times I have thought I got it correct the print starts with the head way to high.
Can someone please explain to me like Im a child what I am doing wrong?
Hello @IamDan !
How do you save the config?
Save_config in the console
I’m just a bit confused:
Sometimes you have y_offset in [bltouch], sometimes not. Do you delete it?
I’ve never touched the y offset. I’m starting to think I should have stayed with marlin :person_facepalming:
Should I delete the printer.cfg and start again?
Sorry, I meant z_offset.
Yes, I did delete it and replace it. Im basically clutching at straws and trying combinations of everything. Should the values at the bottom of my config (probe_calibrate results) be copied into the z_offset position? Do I leave z_offset at 0?
When you calibrate the probe and the z_offset, you should not do anything with the values in the config.
Klipper stores the actual value in an area below the config lines.
#*# [bltouch]
#*# z_offset = 1.740
The problem is that after a PROBE_CALIBRATE it will comment out the bltouch z_offset, add its own value at the bottom and then proceed to complain that there is no z_offset value
Can you upload the complete
block?
#*# [bed_mesh 60 Deg C]
#*# version = 1
#*# points =
#*# 	  0.240000, 0.055000, 0.022500, 0.047500, 0.102500
#*# 	  0.232500, 0.075000, 0.062500, 0.100000, 0.162500
#*# 	  0.187500, 0.042500, 0.042500, 0.077500, 0.135000
#*# 	  0.217500, 0.060000, 0.042500, 0.047500, 0.065000
#*# 	  0.187500, 0.050000, 0.047500, 0.060000, 0.090000
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 15.0
#*# max_x = 188.0
#*# min_y = 15.0
#*# max_y = 191.0
# Client variable macro for your printer.cfg
#[gcode_macro _CLIENT_VARIABLE]
#variable_use_custom_pos   : False ; use custom park coordinates for x,y [True/False]
#variable_custom_park_x    : 0.0   ; custom x position; value must be within your defined min and max of X
#variable_custom_park_y    : 0.0   ; custom y position; value must be within your defined min and max of Y
#variable_custom_park_dz   : 2.0   ; custom dz value; the value in mm to lift the nozzle when move to park position
#variable_retract          : 1.0   ; the value to retract while PAUSE
#variable_cancel_retract   : 5.0   ; the value to retract while CANCEL_PRINT
#variable_speed_retract    : 35.0  ; retract speed in mm/s
#variable_unretract        : 1.0   ; the value to unretract while RESUME
#variable_speed_unretract  : 35.0  ; unretract speed in mm/s
#variable_speed_hop        : 15.0  ; z move speed in mm/s
#variable_speed_move       : 100.0 ; move speed in mm/s
#variable_park_at_cancel   : False ; allow to move the toolhead to park while execute CANCEL_PRINT [True/False]
#variable_park_at_cancel_x : None  ; different park position during CANCEL_PRINT [None/Position as Float]; park_at_cancel must be True
#variable_park_at_cancel_y : None  ; different park position during CANCEL_PRINT [None/Position as Float]; park_at_cancel must be True
## !!! Caution [firmware_retraction] must be defined in the printer.cfg if you set use_fw_retract: True !!!
#variable_use_fw_retract   : False ; use fw_retraction instead of the manual version [True/False]
#variable_idle_timeout     : 0     ; time in sec until idle_timeout kicks in. Value 0 means that no value will be set or restored
#variable_runout_sensor    : ""    ; If a sensor is defined, it will be used to cancel the execution of RESUME in case no filament is detected.
##                                   Specify the config name of the runout sensor e.g "filament_switch_sensor runout". Hint use the same as in your printer.cfg
## !!! Custom macros, please use with care and review the section of the corresponding macro.
## These macros are for simple operations like setting a status LED. Please make sure your macro does not interfere with the basic macro functions.
## Only  single line commands are supported, please create a macro if you need more than one command.
#variable_user_pause_macro : ""    ; Everything inside the "" will be executed after the klipper base pause (PAUSE_BASE) function
#variable_user_resume_macro: ""    ; Everything inside the "" will be executed before the klipper base resume (RESUME_BASE) function
#variable_user_cancel_macro: ""    ; Everything inside the "" will be executed before the klipper base cancel (CANCEL_PRINT_BASE) function
#gcode:
[gcode_macro START_PRINT]
    {% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(190)|float %}
    # Start bed heating
    M140 S{BED_TEMP}
    # Use absolute coordinates
    G90
    # Reset the G-Code Z offset (adjust Z offset if needed)
    SET_GCODE_OFFSET Z=0.0
    # Home the printer
    G28
    G1 Z5 F3000
    G1 Z0.15 F300
    # Wait for bed to reach temperature
    M190 S{BED_TEMP}
    # Set and wait for nozzle to reach temperature
    M109 S{EXTRUDER_TEMP}
[gcode_macro END_PRINT]
    M140 S0
    M104 S0
    M106 S0
    G91
    G1 X-2 Y-2 E-3 F300
    # Raise nozzle by 10mm
    G1 Z10 F3000
    G90
    # Disable steppers
    M84
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 69.463
#*# pid_ki = 1.209
#*# pid_kd = 997.664
#*# [bltouch]
#*# z_offset = 2.500
Is it normal that if I run PROBE_CALIBRATE again that it will add a new block while keeping the old?
Issue is, you have multiple
blocks.
Only the first one is valid.
Also you have config code after the first
block. That’s not proper too.
Delete all lines that start with #*# - only those - and add this at the very end:
#*# version = 1
#*# points =
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 15.0
#*# max_x = 188.0
#*# min_y = 15.0
#*# max_y = 191.0
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 69.463
#*# pid_ki = 1.209
#*# [bltouch]
Thankyou! that appears to have cleared the error. Unfortunatly I start work in an hour and woont be able to test it for another 9 or so hours
Have fun at work - take care.
Fun and work? HAHA
Thanks again I really do appreciate all your help
I just want to say thanks agin for your help. The first layers are going down nicely
