Problem with Z offset
Printer Model: Ender 3
MCU / Printerboard: Netbook / Skr Mini E3 V2
First of all, good day. I can’t load the klippy.log since I’m pretty new to klipper and have no idea where it is located. I have a problem with the Z OFFSET, my problem is that in each print it varies +0.400 or -0.400, it depends on whether when the print starts the nozzle is high or low, I must raise the z offset by +0.400 or lower the z offset by -0.400 . What could be the problem? It should be noted that every time I modify the z offset I use the save_config command.
See point #3 here: klipper/docs/Contact.md at master · Klipper3d/klipper · GitHub
