Printer Model:
MCU / Printerboard:
…good afternoon, I have performed the Klipper Z offset calibration, but when starting to print the print head is still too high! Is there a way to add a g-code in the start code section of Klipper to adjust the z offset to the required amount(-0.095)?
Did you properly save the determined value?
When you home Z and then move it to Z=0 how far off of the bed is the nozzle?
For me it sounds that you did not store the value as needed.
As the post template, you did not delete, requests the klippy.log you should attach it to your next post!
As I’m currently not knowing whether or not it will contain the interesting SAVE_CONFIG section, you better upload your printer.cfg as well.
Hi, I did accept the settings and then save_config afterwards and restart firmware.
klippy.log (1.9 MB)
printer.cfg (18.3 KB)
There is at least the proper entry:
#*# [bltouch]
#*# z_offset = 3.701
What about my question:
The nozzle is a piece of paper thickness away from the bed
You didn’t measure your Z offset with a paper though?
Redo the Z calibration and check whether or not it determines a different value.
