After update i cant connect
Printer Model: vcore 3.1
MCU / Printerboardoctopus pro + Ebb42
klippy.log (6).txt (5.4 MB)
This morning I made a short impression… And at the end I have updated, everything except the Octopus Pro, because it is the 429 and the Ebb42.
Well, after rebooting have come lis problems … Fluidd does not connect to the printer… I guess it will have to do with the update
I can read these error
mcu ‘mcu’: Unable to connect
Error configuring printe
There is a method for revert update?
What is everything?
Have you checked that the serial is still valid:
baud = 250000
serial = /dev/serial/by-id/usb-Klipper_stm32f429xx_3A0039000D50304738313820-if00
Have you checked the USB connection?
If your Pi OS is Debian Bullseye, you’re like affected by this bug.
Follows the instruction on that topic and klipper should be able to connect after a reboot.
No… The lottery won’t touch me… but this.
I read few days ago and believed that it could be produced by updating klipper, and I have not updated klipper, if the rest…
When I get home I’ll try
Same thing happened to me yesterday. There were two problems. As someone else mentioned herein, the USB connection changed. The "serial = " statement had changed. The second problem probably affects only a few users. I have a BME280 hooked up to the PI on I2C 1. The RPI mcu would no longer load. I had to reload the RPI firmware with the make command and reflash.
Afterward, all was well.
i have checked, and that i am affected
the response of:
pi@fluiddpi:~ $ apt-cache policy udev
is:
udev:
Installed: 247.3-7+rpi1+deb11u2
Candidate: 247.3-7+rpi1+deb11u2
Version table:
252.5-2~bpo11+1 100
100 Index of /debian bullseye-backports/main armhf Packages
*** 247.3-7+rpi1+deb11u2 500
500 Index of /raspbian bullseye/main armhf Packages
100 /var/lib/dpkg/status
It’s the opposite actually: the bug comes with OS system package updates.
Mainsail crew made a onliner fix:
curl -sSL https://raw.githubusercontent.com/mainsail-crew/MainsailOS/develop/patches/udev-fix.sh | bash
WORKS…
thanks… to all
