Printer Model: DIY coreXY Printer
MCU / Printerboard: RAMPS-FDv2
Hello.
I am using printermods xchange and would like to switch between the following three with the T command.
1.0.4mm diameter direct extrusion
2.0.2mm diameter Bowden extrusion
3.0.4mm diameter Bowden extrusion, motor shared with #2.
I tried to apply pressure advance on #3 and started printing the tuning tower and got an error.
console msg : Unable to infer active extruder stepper.
Is there any solution?
klippy.log (11.8 KB)
