Printer Model: Generic
MCU / Printerboard:RPI4/BTT SKR3EZ
klippy.log (1.4 MB)
…All working fine except fot the BLtouh, On power it cycles as it should, But on home all, X and Y home fine, Z does not move up or down. The Bltouch does not trigger the probe either up or down , Manually by command or by the OS. Have replaced the Bltouch, Tried new wires, Have even moved the probe connect to the Z endstop. Nothing mach a difference. Nothing changes.
I am at wits end with this. Have tried all I can see on the internet to no avail.
Help appreciated and thanked in advance
James
