Hello Guys,
I have the following problem i installed the bltouch senor to my anycubic chiron, updated made sure every pin is connected right and that i should work, after installing all i ran de the debug commads to lower the pin and checked the status and it showed open, then i pushed the pin and ot said triggered. But now the problem starts. As soon as i try to home the z with the bltouch i moves to the save home Location then klipper restarts cause it crashed saying that it cant send a singal thats is allready active. I assume thats cause the pin should be triggered but it is shown as open once i run the query command. So basically it triggers when i manually run the debug mode but if i try to, probe oder after a reset its doesnt read the state correctly. Does anyone have a Suggestion?
Kind regards Shiggi
klippy.log.txt (98.6 KB)
