Printer Model: sunlu s8 with sprite kit hot end
MCU / Printerboard: ender 4.2.7
klippy (24).log (390.7 KB)
i used the supplied wiring flat ribbon harness.
there are a few unlabeled connectors that the instructions dont even mention.
when i send the heat nozzle command… i hear the fan dip and then the whole systems restarts.
