USB port changes
Printer Model: Home-built Rostock type Delta
MCU / Printerboard: Arduino MEGA2560, Raspberry Pi 2
klippy.zip (1.5 MB)
Describe your issue: I have been finding problems flashing an ATMEGA2650 and communicating with it from a Pi 2B. Although I have come up with an answer, it is not completely satisfactory. Has anybody a better answer?
DETAILS: Using the method in most documents and videos, vis: use ls /dev/serial/by-id/* to get the I.D. of the port, which in my case was: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_856323331363517080D0-if00
and using this both as a flash address and in the printer.cfg file
The above method repeatedly failed, even with different Arduino boards and Raspberry Pis. But using dmesg | tail gave me /dev/ttyACM0 which, used in both flash and printer.cfg did work satisfactorily.
The problem arises if there is a temporary stutter in the connection between the Pi and the Arduino which results in /dev/ttyACM0 being disconnected and a new connection, /dev/ttyACM1 being created so Klipper is now not communicating.
Any solution is gratefully received.
From Linux OS view and also Klipper’s view both
and
/dev/ttyACM0
are equivalent. In fact they are the same just in a different representation.
I cannot really think about a reason why there should be a difference, except some Linux permission issues.
In any case you could probably use UDEV rules to avoid the described scenario between ACM0 and ACM1. See [How To] Force a specific USB device to a certain TTY · GitHub for an example
I had noticed the symlink pi@miranda:~/printer_data/logs $ ls -l /dev/serial/by-id/
total 0
lrwxrwxrwx 1 root root 13 Feb 17 11:23 usb-Arduino__www.arduino.cc__0042_856323331363517080D0-if00 → …/…/ttyACM0
but it does not work even now after I have had success with /dev/ttyACM0. I think that it flashed O.K., but perhaps the string was too long for Klipper??
I will lokk at how to force the USB to a TTY
Thanks,
Mike
Thank you Sineos, I set up a new rule and it seems to work.
KERNEL=="ttyACM[0-9]*", SUBSYSTEM=="tty", ATTRS{idVendor}=="2341", ATTRS{idProduct}=="0042", SYMLINK="ttyP3D"
Mike
