Printer Model: VCore 31
MCU / Printerboard: Octopus Pro+ SHT42
klippy.log (15.9 KB)
I am trying to reorganize the printer configuration… but I am encountering problems related to RPi, and it is that it does not let me create (configuration) files, it returns the message “internal server error”.
I have also tried with SCP, but when I try to copy any file, created in Windows and copied… it tells me that I do NOT have permissions.
I know very little about Rpi/linux, so I have googled, and it is supposed that from the console if I send sudo chmod 777 (File/folder name), I would have to give all the permissions, but nothing, the permissions I think if given, (LS -L…) But I can’t create anything from Fluidd.
It sounds to me, that some time ago, I had to make a modification, related to permissions…
What can be?
