I don’t know for sure (somebody with more knowledge of the internals of Klipper could answer this) but I suspect that the load does go up when the problem happens.
If you look at your klippy.log, you can see where one of the “Timer Too Close” events takes place by what happens with the “bytes_retransmit” value and how it climbs:
toolhead: max_velocity: 200.000000
max_accel: 5000.000000
minimum_cruise_ratio: 0.500000
square_corner_velocity: 10.000000
Stats 3175.8: gcodein=0 mcu: mcu_awake=0.023 mcu_task_avg=0.000008 mcu_task_stddev=0.000013 bytes_write=1133639 bytes_read=717668 bytes_retransmit=160 bytes_invalid=0 send_seq=38254 receive_seq=38254 retransmit_seq=29552 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=3 upcoming_bytes=0 freq=168004562 MKS_THR: mcu_awake=0.003 mcu_task_avg=0.000011 mcu_task_stddev=0.000018 bytes_write=415076 bytes_read=348904 bytes_retransmit=112 bytes_invalid=0 send_seq=17068 receive_seq=17068 retransmit_seq=14353 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=56 upcoming_bytes=0 freq=12048566 adj=12048313 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000013 bytes_write=10425 bytes_read=34239 bytes_retransmit=0 bytes_invalid=0 send_seq=1710 receive_seq=1710 retransmit_seq=0 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=50000688 adj=49999407 MCU: temp=34.6 heater_bed: target=70 temp=70.2 pwm=0.221 chamber: target=0 temp=28.9 pwm=0.000 sd_pos=96683 sysload=0.19 cputime=185.484 memavail=638856 print_time=1577.462 buffer_time=2.589 print_stall=0 extruder: target=230 temp=229.7 pwm=0.271
Stats 3176.8: gcodein=0 mcu: mcu_awake=0.023 mcu_task_avg=0.000008 mcu_task_stddev=0.000013 bytes_write=1135426 bytes_read=718094 bytes_retransmit=160 bytes_invalid=0 send_seq=38292 receive_seq=38289 retransmit_seq=29552 srtt=0.001 rttvar=0.001 rto=0.025 ready_bytes=876 upcoming_bytes=0 freq=168004560 MKS_THR: mcu_awake=0.004 mcu_task_avg=0.000011 mcu_task_stddev=0.000018 bytes_write=415514 bytes_read=349046 bytes_retransmit=112 bytes_invalid=0 send_seq=17076 receive_seq=17073 retransmit_seq=14353 srtt=0.001 rttvar=0.001 rto=0.025 ready_bytes=215 upcoming_bytes=0 freq=12048567 adj=12048321 rpi: mcu_awake=0.000 mcu_task_avg=0.000009 mcu_task_stddev=0.000015 bytes_write=10431 bytes_read=34268 bytes_retransmit=0 bytes_invalid=0 send_seq=1711 receive_seq=1711 retransmit_seq=0 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=50000688 adj=49999416 MCU: temp=34.5 heater_bed: target=70 temp=70.0 pwm=0.617 chamber: target=0 temp=28.8 pwm=0.000 sd_pos=97100 sysload=0.19 cputime=185.651 memavail=638856 print_time=1578.307 buffer_time=2.432 print_stall=0 extruder: target=230 temp=229.7 pwm=0.271
Stats 3177.8: gcodein=0 mcu: mcu_awake=0.023 mcu_task_avg=0.000008 mcu_task_stddev=0.000013 bytes_write=1137335 bytes_read=718520 bytes_retransmit=900 bytes_invalid=0 send_seq=38327 receive_seq=38324 retransmit_seq=38327 srtt=0.001 rttvar=0.001 rto=0.400 ready_bytes=739 upcoming_bytes=1336 freq=168004555 MKS_THR: mcu_awake=0.004 mcu_task_avg=0.000011 mcu_task_stddev=0.000018 bytes_write=416136 bytes_read=349151 bytes_retransmit=852 bytes_invalid=0 send_seq=17087 receive_seq=17084 retransmit_seq=17087 srtt=0.002 rttvar=0.002 rto=0.400 ready_bytes=343 upcoming_bytes=658 freq=12048567 adj=12048327 rpi: mcu_awake=0.000 mcu_task_avg=0.000009 mcu_task_stddev=0.000015 bytes_write=10437 bytes_read=34284 bytes_retransmit=0 bytes_invalid=0 send_seq=1712 receive_seq=1712 retransmit_seq=0 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=50000687 adj=49999419 MCU: temp=34.5 heater_bed: target=70 temp=70.1 pwm=0.263 chamber: target=0 temp=29.1 pwm=0.000 sd_pos=97435 sysload=0.25 cputime=185.745 memavail=638856 print_time=1579.002 buffer_time=2.126 print_stall=0 extruder: target=230 temp=229.6 pwm=0.271
Stats 3178.8: gcodein=0 mcu: mcu_awake=0.023 mcu_task_avg=0.000008 mcu_task_stddev=0.000013 bytes_write=1137335 bytes_read=718696 bytes_retransmit=1085 bytes_invalid=0 send_seq=38327 receive_seq=38324 retransmit_seq=38327 srtt=0.001 rttvar=0.001 rto=0.800 ready_bytes=739 upcoming_bytes=4026 freq=168004555 MKS_THR: mcu_awake=0.004 mcu_task_avg=0.000011 mcu_task_stddev=0.000018 bytes_write=416136 bytes_read=349151 bytes_retransmit=1037 bytes_invalid=0 send_seq=17087 receive_seq=17084 retransmit_seq=17087 srtt=0.002 rttvar=0.002 rto=0.800 ready_bytes=343 upcoming_bytes=2028 freq=12048567 adj=12048331 rpi: mcu_awake=0.000 mcu_task_avg=0.000009 mcu_task_stddev=0.000015 bytes_write=10443 bytes_read=34300 bytes_retransmit=0 bytes_invalid=0 send_seq=1713 receive_seq=1713 retransmit_seq=0 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=50000692 adj=49999422 MCU: temp=34.5 heater_bed: target=70 temp=70.2 pwm=0.144 chamber: target=0 temp=29.0 pwm=0.000 sd_pos=97770 sysload=0.25 cputime=185.867 memavail=638856 print_time=1580.003 buffer_time=2.127 print_stall=0 extruder: target=230 temp=229.6 pwm=0.271
Stats 3179.8: gcodein=0 mcu: mcu_awake=0.023 mcu_task_avg=0.000008 mcu_task_stddev=0.000013 bytes_write=1137335 bytes_read=718828 bytes_retransmit=1270 bytes_invalid=0 send_seq=38327 receive_seq=38324 retransmit_seq=38327 srtt=0.001 rttvar=0.001 rto=1.600 ready_bytes=739 upcoming_bytes=6641 freq=168004555 MKS_THR: mcu_awake=0.004 mcu_task_avg=0.000011 mcu_task_stddev=0.000018 bytes_write=416136 bytes_read=349151 bytes_retransmit=1222 bytes_invalid=0 send_seq=17087 receive_seq=17084 retransmit_seq=17087 srtt=0.002 rttvar=0.002 rto=1.600 ready_bytes=343 upcoming_bytes=3393 freq=12048567 adj=12048315 rpi: mcu_awake=0.000 mcu_task_avg=0.000009 mcu_task_stddev=0.000015 bytes_write=10449 bytes_read=34316 bytes_retransmit=0 bytes_invalid=0 send_seq=1714 receive_seq=1714 retransmit_seq=0 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=50000690 adj=49999462 MCU: temp=34.5 heater_bed: target=70 temp=70.2 pwm=0.000 chamber: target=0 temp=29.0 pwm=0.000 sd_pos=98105 sysload=0.25 cputime=185.948 memavail=638856 print_time=1581.307 buffer_time=2.430 print_stall=0 extruder: target=230 temp=229.6 pwm=0.271
Stats 3180.8: gcodein=0 mcu: mcu_awake=0.018 mcu_task_avg=0.000008 mcu_task_stddev=0.000012 bytes_write=1137335 bytes_read=718990 bytes_retransmit=1455 bytes_invalid=0 send_seq=38327 receive_seq=38324 retransmit_seq=38327 srtt=0.001 rttvar=0.001 rto=3.200 ready_bytes=739 upcoming_bytes=8512 freq=168004555 MKS_THR: mcu_awake=0.004 mcu_task_avg=0.000011 mcu_task_stddev=0.000018 bytes_write=416136 bytes_read=349151 bytes_retransmit=1407 bytes_invalid=0 send_seq=17087 receive_seq=17084 retransmit_seq=17087 srtt=0.002 rttvar=0.002 rto=3.200 ready_bytes=343 upcoming_bytes=4323 freq=12048567 adj=12048290 rpi: mcu_awake=0.000 mcu_task_avg=0.000009 mcu_task_stddev=0.000015 bytes_write=10455 bytes_read=34332 bytes_retransmit=0 bytes_invalid=0 send_seq=1715 receive_seq=1715 retransmit_seq=0 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=50000688 adj=49999405 MCU: temp=34.5 heater_bed: target=70 temp=70.1 pwm=0.062 chamber: target=0 temp=29.2 pwm=0.000 sd_pos=98328 sysload=0.25 cputime=186.061 memavail=638856 print_time=1582.345 buffer_time=2.466 print_stall=0 extruder: target=230 temp=229.6 pwm=0.271
Transition to shutdown state: MCU shutdown
Dumping gcode input 0 blocks
Dumping 20 requests for client 281473569538976
Received 1605.552658: b'{"id": 281472846572176, "method": "objects/subscribe", "params": {"objects": {"gcode": null, "webhooks": null, "configfile": null, "mcu": null, "mcu MKS_THR": null, "mcu rpi": null, "gcode_macro BED_MESH_CALIBRATE": null, "gcode_macro LINE_PURGE": null, "gcode_macro SMART_PARK": null, "gcode_macro _KAMP_Settings": null, "gcode_macro SHUTDOWN": null, "gcode_macro M300": null, "gcode_macro M141": null, "gcode_macro M191": null, "pause_resume": null, "gcode_macro PAUSE": null, "gcode_macro RESUME": null, "gcode_macro CANCEL_PRINT": null, "gcode_macro PRINT_START": null, "gcode_macro G32": null, "heaters": null, "heater_fan hotend_fan": null, "fan": null, "stepper_enable": null, "tmc2208 extruder": null, "probe": null, "temperature_sensor Printhead MCU": null, "gcode_button poweroffbtn": null, "output_pin beeper": null, "tmc2208 stepper_x": null, "tmc2209 stepper_y": null, "tmc2208 stepper_z": null, "heater_bed": null, "heater_generic chamber": null, "heater_fan chamber_fan": null, "display_status": null, "neopixel fysetc_mini12864": null, "gcode_move": null, "print_stats": null, "virtual_sdcard": null, "firmware_retraction": null, "idle_timeout": null, "bed_mesh": null, "exclude_object": null, "gcode_macro SET_PAUSE_NEXT_LAYER": null, "gcode_macro SET_PAUSE_AT_LAYER": null, "gcode_macro SET_PRINT_STATS_INFO": null, "gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL": null, "gcode_macro _CLIENT_EXTRUDE": null, "gcode_macro _CLIENT_RETRACT": null, "gcode_macro LOAD_FILAMENT": null, "gcode_macro UNLOAD_FILAMENT": null, "filament_switch_sensor my_sensor": null, "motion_report": null, "query_endstops": null, "system_stats": null, "manual_probe": null, "toolhead": null, "extruder": null, "screws_tilt_adjust": ["results", "error"]}, "response_template": {"method": "process_status_update"}}}'
Received 1605.555011: b'{"id": 281472881594576, "method": "list_endpoints", "params": {}}'
Received 1605.804505: b'{"id": 281472846570880, "method": "objects/subscribe", "params": {"objects": {"webhooks": null, "print_stats": null, "bed_mesh": null, "configfile": null, "display_status": null, "fan": null, "gcode_move": null, "idle_timeout": null, "pause_resume": null, "toolhead": null, "virtual_sdcard": null, "firmware_retraction": null, "motion_report": null, "exclude_object": null, "manual_probe": null, "screws_tilt_adjust": ["results", "error"], "extruder": null, "heater_bed": null, "heater_generic chamber": null, "temperature_sensor Printhead MCU": null, "heater_fan hotend_fan": null, "heater_fan chamber_fan": null, "filament_switch_sensor my_sensor": null, "output_pin beeper": null, "neopixel fysetc_mini12864": null, "gcode": null, "mcu": null, "mcu MKS_THR": null, "mcu rpi": null, "gcode_macro BED_MESH_CALIBRATE": null, "gcode_macro LINE_PURGE": null, "gcode_macro SMART_PARK": null, "gcode_macro _KAMP_Settings": null, "gcode_macro SHUTDOWN": null, "gcode_macro M300": null, "gcode_macro M141": null, "gcode_macro M191": null, "gcode_macro PAUSE": null, "gcode_macro RESUME": null, "gcode_macro CANCEL_PRINT": null, "gcode_macro PRINT_START": null, "gcode_macro G32": null, "heaters": null, "stepper_enable": null, "tmc2208 extruder": null, "probe": null, "gcode_button poweroffbtn": null, "tmc2208 stepper_x": null, "tmc2209 stepper_y": null, "tmc2208 stepper_z": null, "gcode_macro SET_PAUSE_NEXT_LAYER": null, "gcode_macro SET_PAUSE_AT_LAYER": null, "gcode_macro SET_PRINT_STATS_INFO": null, "gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL": null, "gcode_macro _CLIENT_EXTRUDE": null, "gcode_macro _CLIENT_RETRACT": null, "gcode_macro LOAD_FILAMENT": null, "gcode_macro UNLOAD_FILAMENT": null, "query_endstops": null, "system_stats": null}, "response_template": {"method": "process_status_update"}}}'
Received 1606.048399: b'{"id": 281472882057568, "method": "objects/list", "params": {}}'
Received 1606.051112: b'{"id": 281472882057568, "method": "objects/query", "params": {"objects": {"configfile": null}}}'
Received 1606.291255: b'{"id": 281472855941712, "method": "register_remote_method", "params": {"response_template": {"method": "shutdown_machine"}, "remote_method": "shutdown_machine"}}'
Received 1606.295009: b'{"id": 281472855943680, "method": "register_remote_method", "params": {"response_template": {"method": "reboot_machine"}, "remote_method": "reboot_machine"}}'
Received 1606.298168: b'{"id": 281472882057568, "method": "register_remote_method", "params": {"response_template": {"method": "pause_job_queue"}, "remote_method": "pause_job_queue"}}'
Received 1606.300718: b'{"id": 281472882057568, "method": "register_remote_method", "params": {"response_template": {"method": "start_job_queue"}, "remote_method": "start_job_queue"}}'
Received 1606.307139: b'{"id": 281472846572320, "method": "objects/query", "params": {"objects": {"heaters": null}}}'
Received 1606.307691: b'{"id": 281472846570784, "method": "objects/query", "params": {"objects": {"heaters": null}}}'
Received 1606.336690: b'{"id": 281472846573472, "method": "objects/query", "params": {"objects": {"extruder": ["can_extrude"]}}}'
Received 1606.408810: b'{"id": 281472846571072, "method": "info", "params": {}}'
Received 1606.409698: b'{"id": 281472846323424, "method": "objects/list", "params": {}}'
Received 1606.409698: b'{"id": 281472846322752, "method": "gcode/help", "params": {}}'
Received 1606.460271: b'{"id": 281472846322752, "method": "objects/subscribe", "params": {"objects": {"gcode": null, "webhooks": null, "configfile": null, "mcu": null, "mcu MKS_THR": null, "mcu rpi": null, "gcode_macro BED_MESH_CALIBRATE": null, "gcode_macro LINE_PURGE": null, "gcode_macro SMART_PARK": null, "gcode_macro _KAMP_Settings": null, "gcode_macro SHUTDOWN": null, "gcode_macro M300": null, "gcode_macro M141": null, "gcode_macro M191": null, "pause_resume": null, "gcode_macro PAUSE": null, "gcode_macro RESUME": null, "gcode_macro CANCEL_PRINT": null, "gcode_macro PRINT_START": null, "gcode_macro G32": null, "heaters": null, "heater_fan hotend_fan": null, "fan": null, "stepper_enable": null, "tmc2208 extruder": null, "probe": null, "temperature_sensor Printhead MCU": null, "gcode_button poweroffbtn": null, "output_pin beeper": null, "tmc2208 stepper_x": null, "tmc2209 stepper_y": null, "tmc2208 stepper_z": null, "heater_bed": null, "heater_generic chamber": null, "heater_fan chamber_fan": null, "display_status": null, "neopixel fysetc_mini12864": null, "gcode_move": null, "print_stats": null, "virtual_sdcard": null, "firmware_retraction": null, "idle_timeout": null, "bed_mesh": null, "exclude_object": null, "gcode_macro SET_PAUSE_NEXT_LAYER": null, "gcode_macro SET_PAUSE_AT_LAYER": null, "gcode_macro SET_PRINT_STATS_INFO": null, "gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL": null, "gcode_macro _CLIENT_EXTRUDE": null, "gcode_macro _CLIENT_RETRACT": null, "gcode_macro LOAD_FILAMENT": null, "gcode_macro UNLOAD_FILAMENT": null, "filament_switch_sensor my_sensor": null, "motion_report": null, "query_endstops": null, "system_stats": null, "manual_probe": null, "toolhead": null, "extruder": null, "screws_tilt_adjust": ["results", "error"]}, "response_template": {"method": "process_status_update"}}}'
Received 1606.555525: b'{"id": 281472846323088, "method": "objects/subscribe", "params": {"objects": {"webhooks": null, "print_stats": null, "temperature_sensor Printhead MCU": null, "heater_bed": null, "heater_generic chamber": null, "extruder": null, "bed_mesh": null, "configfile": null, "display_status": null, "fan": null, "gcode_move": null, "idle_timeout": null, "pause_resume": null, "toolhead": null, "virtual_sdcard": null, "firmware_retraction": null, "motion_report": null, "exclude_object": null, "manual_probe": null, "screws_tilt_adjust": ["results", "error"], "heater_fan hotend_fan": null, "heater_fan chamber_fan": null, "filament_switch_sensor my_sensor": null, "output_pin beeper": null, "neopixel fysetc_mini12864": null, "gcode": null, "mcu": null, "mcu MKS_THR": null, "mcu rpi": null, "gcode_macro BED_MESH_CALIBRATE": null, "gcode_macro LINE_PURGE": null, "gcode_macro SMART_PARK": null, "gcode_macro _KAMP_Settings": null, "gcode_macro SHUTDOWN": null, "gcode_macro M300": null, "gcode_macro M141": null, "gcode_macro M191": null, "gcode_macro PAUSE": null, "gcode_macro RESUME": null, "gcode_macro CANCEL_PRINT": null, "gcode_macro PRINT_START": null, "gcode_macro G32": null, "heaters": null, "stepper_enable": null, "tmc2208 extruder": null, "probe": null, "gcode_button poweroffbtn": null, "tmc2208 stepper_x": null, "tmc2209 stepper_y": null, "tmc2208 stepper_z": null, "gcode_macro SET_PAUSE_NEXT_LAYER": null, "gcode_macro SET_PAUSE_AT_LAYER": null, "gcode_macro SET_PRINT_STATS_INFO": null, "gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL": null, "gcode_macro _CLIENT_EXTRUDE": null, "gcode_macro _CLIENT_RETRACT": null, "gcode_macro LOAD_FILAMENT": null, "gcode_macro UNLOAD_FILAMENT": null, "query_endstops": null, "system_stats": null}, "response_template": {"method": "process_status_update"}}}'
Received 1606.800701: b'{"id": 281472846323616, "method": "objects/subscribe", "params": {"objects": {"webhooks": null, "print_stats": null, "temperature_sensor Printhead MCU": null, "heater_bed": null, "heater_generic chamber": null, "extruder": null, "bed_mesh": null, "configfile": null, "display_status": null, "fan": null, "gcode_move": null, "idle_timeout": null, "pause_resume": null, "toolhead": null, "virtual_sdcard": null, "firmware_retraction": null, "motion_report": null, "exclude_object": null, "manual_probe": null, "screws_tilt_adjust": ["results", "error"], "heater_fan hotend_fan": null, "heater_fan chamber_fan": null, "filament_switch_sensor my_sensor": null, "output_pin beeper": null, "neopixel fysetc_mini12864": null, "gcode": null, "mcu": null, "mcu MKS_THR": null, "mcu rpi": null, "gcode_macro BED_MESH_CALIBRATE": null, "gcode_macro LINE_PURGE": null, "gcode_macro SMART_PARK": null, "gcode_macro _KAMP_Settings": null, "gcode_macro SHUTDOWN": null, "gcode_macro M300": null, "gcode_macro M141": null, "gcode_macro M191": null, "gcode_macro PAUSE": null, "gcode_macro RESUME": null, "gcode_macro CANCEL_PRINT": null, "gcode_macro PRINT_START": null, "gcode_macro G32": null, "heaters": null, "stepper_enable": null, "tmc2208 extruder": null, "probe": null, "gcode_button poweroffbtn": null, "tmc2208 stepper_x": null, "tmc2209 stepper_y": null, "tmc2208 stepper_z": null, "gcode_macro SET_PAUSE_NEXT_LAYER": null, "gcode_macro SET_PAUSE_AT_LAYER": null, "gcode_macro SET_PRINT_STATS_INFO": null, "gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL": null, "gcode_macro _CLIENT_EXTRUDE": null, "gcode_macro _CLIENT_RETRACT": null, "gcode_macro LOAD_FILAMENT": null, "gcode_macro UNLOAD_FILAMENT": null, "query_endstops": null, "system_stats": null}, "response_template": {"method": "process_status_update"}}}'
Received 1607.057697: b'{"id": 281472846323472, "method": "objects/query", "params": {"objects": {"extruder": ["can_extrude"]}}}'
Received 1768.964960: b'{"id": 281472846323472, "method": "gcode/script", "params": {"script": "SDCARD_PRINT_FILE FILENAME=\\"CoverBox.gcode\\""}}'
Virtual sdcard (97304): '188 Y60.932 E.01783\nG1 X234.347 Y68.091 E.38563\nG1 X234.347 Y68.739 E.01783\nG1 X226.54 Y60.932 E.42053\nG1 X225.892 Y60.932 E.01783\nG1 X234.347 Y69.386 E.45543\nG1 X234.347 Y70.034 E.01783\nG1 X225.245 Y60.932 E.49033\nG1 X224.597 Y60.932 E.01783\nG1 X234.347 Y70.682 E.52523\nG1 X234.347 Y71.33 E.01783\nG1 X223.949 Y60.932 E.56013\nG1 X223.301 Y60.932 E.01783\nG1 X234.347 Y71.978 E.59503\nG1 X234.347 Y72.626 E.01783\nG1 X222.653 Y60.932 E.62993\nG1 X222.005 Y60.932 E.01783\nG1 X234.347 Y73.274 E.66483\nG1 X234.347 Y73.921 E.01783\nG1 X221.357 Y60.932 E.69973\nG1 X220.71 Y60.932 E.01783\nG1 X234.347 Y74.569 E.73463\nG1 X234.347 Y75.217 E.01783\nG1 X220.062 Y60.932 E.76953\nG1 X219.414 Y60.932 E.01783\nG1 X234.347 Y75.865 E.80443\nG1 X234.347 Y76.513 E.01783\nG1 X218.766 Y60.932 E.83932\nG1 X218.118 Y60.932 E.01783\nG1 X234.347 Y77.161 E.87422\nG1 X234.347 Y77.809 E.01783\nG1 X217.47 Y60.932 E.90912\nG1 X216.822 Y60.932 E.01783\nG1 X234.347 Y78.456 E.94402\nG1 X234.347 Y79.104 E.01783\nG1 X216.175 Y60.932 E.97892\nG1 X215.527 Y60.932 E.01783\n'
Upcoming (98328): 'G1 X234.347 Y79.752 E1.01382\nG1 X234.347 Y80.4 E.01783\nG1 X214.879 Y60.932 E1.04872\nG1 X214.231 Y60.932 E.01783\nG1 X234.347 Y81.'
gcode state: absolute_coord=True absolute_extrude=False base_position=[0.0, 0.0, 0.08246271022209753, 3851.4404194000263] last_position=[234.347, 79.752, 0.7824627102220975, 3926.665461700036] homing_position=[0.0, 0.0, 0.0, 0.0] speed_factor=0.016666666666666666 extrude_factor=0.97 speed=109.14574999999999
Reactor garbage collection: (1906.29566195, 1945.613862635, 0.0)
MCU 'mcu' shutdown: Timer too close
I’m suggesting that you lower the number of microsteps to 16 because it’s easy to do and often fixes the problem.
If it doesn’t solve your problem, then you will need to read through the Knowledge Base article on Timer Too Close I referenced above.
