Timer too close
Timer too close
Background
A “Timer too close” error occurs when the MCU is asked to schedule an action at a time that is already in the past. This typically results from delayed communication between the host and the MCU - for instance, if the host was busy or the message was blocked en route.
:warning: Important:
Klipper can identify what command was too late, but cannot determine why the delay occurred. The root cause is often external - such as USB congestion from a webcam or high system load - and beyond Klipper’s direct control.
Causes and Potential Solutions
The klippy.log will mostly contain the fact that this issue occurred, but cannot offer a direct pointer to the cause. Carefully analyzing and working through the points listed below is needed to pinpoint it.
  • High CPU or system load on the host (e.g. Raspberry Pi)
    Close or disable other resource-intensive processes (e.g., locally running interfaces or services, webcam streaming, browser tabs). Simplify your setup to reduce the load. The host computer should be dedicated to running only Klipper and its official environment for the best results.
  • High disk activity or SD card issues
    Check the SD card for errors and performance degradation. Replace aging or low-quality cards. Use high-speed, reliable storage.
  • Memory swapping due to low free RAM
    Monitor memory usage (htop, free -m) and avoid situations that trigger swapping. Reduce unnecessary services or increase RAM.
  • Overheating and CPU throttling
    Ensure the SBC (e.g. Raspberry Pi) has proper cooling. Use heat sinks and fans where appropriate to prevent CPU slowdowns.
  • Undervoltage conditions
    Look for Under-voltage detected! messages in system logs. Use a stable and sufficient power supply for the SBC and MCU.
  • USB, UART, or CAN wiring faults
    Avoid running communication lines (USB, UART, CAN) alongside current-carrying cables like heater or stepper wires. Use shielded cables, ferrite cores, and keep data cables short and well-routed. Carefully inspect all wiring for potential damages.
  • ElectroMagnetic Interference (EMI)
    EMI can corrupt or delay messages. Improve grounding, avoid wire bundles that mix power and signal, and shield vulnerable cables.
  • Conflicting USB devices (e.g. webcams, displays, hubs)
    Remove unnecessary peripherals that may overload the USB bus. Webcams in particular can monopolize bandwidth and delay message delivery.
    Using an (external) powered USB hub can improve the situation, but it can also make it worse. Some host computers and USB hubs do not work well together.
  • Incorrect firmware Clock Reference setting
    Ensure the correct Clock Reference is selected in make menuconfig when building Klipper for your MCU. Boards with multiple hardware revisions may require different settings.
  • Running Klipper inside a Virtual Machine (VM)
    VMs introduce latency and timing inconsistencies. Run Klipper directly on the host hardware for best reliability.
  • Poorly written macros or command spam from slicers
    Identify macros that flood Klipper with frequent updates (e.g. unnecessary SET_FAN_SPEED commands or returning additional values like temperatures at a high frequency).
    Review your slicer’s G-code for high-frequency commands (e.g. dozens of M106 commands per second) and reduce them.
  • Unofficial modules or patched Klipper forks
    Remove custom modifications or third-party modules not part of the official Klipper repository, as they can cause instability or overload the command queue.
"MCU 'mcu' shutdown: Timer too close" when attempting to BED_MESH_CALIBRATE
Help needed with "MCU 'mcu' shutdown: Timer too close" :-(
Klipper 'mcu' shutdown: timer too close
MCU 'mcu' shutdown: Timer too close after tuning Trinamic drivers
About the Knowledge Base category / Table of Contents
"MCU 'mcu' shutdown: Timer too close" - unknown cause
Timer too close, trying to understand log files
Won't home , MCU 'mcu' shutdown: Timer too close
Another MCU 'mcu' shutdown: Timer too close
EBB 36: Timer Too Close
MCU 'mcu' shutdown: Timer too close on voron 2.4
MCU 'mcu' shutdown: Timer too close during BED_MESH_CALIBRATE
MCU timer too close -- suspected rpi 3b+ overload
static_string_id=Timer too close
Yet another Timer too close
MCU discconnecting, rpi not respoding
Help with Troubleshooting: MCU timer too close error
Interpretation Help needed: MCU 'mcu' shutdown: Timer too close
Extruder doesn't extrude
MKS_THR shutdown: timer too close
Missed scheduling of next digital out event
Sudden Move Queue Overflow
Timer too close with SB2040
Need help with "verify_heater extruder"
"MCU 'mcu' shutdown: Timer too close.... Random
Strange behavior on XY-movement after update
Klipper Expander MCU Shutdown: Timer too close
Timer too close, yet another. Pretty sure this is a bug
"Timer too close" at specific point in a gcode
"Timer too close", always at the same point in gcode
Printer cancels randomly (Timer too close)
Mcu: timer is too close
MCU 'EBBCan' shutdown: Timer too close
Ebb sb2209 usb MCU "EBB" shutdown: Timer too close
Getting MCU 'mcu' shutdown: Timer too close starting print
Internal error on command:"G2"
Mainsail/klipper is stalling/pausing during printing
Random erratic extruder movements at the beginning of the print
Timer too close - only in Copy/Mirror-Mode - Idex
Timer Too Close Error: Help interpretting the logs
X86_64 linux Shutdown: Timer too close
Manta M5P MCU lost
MCU 'mcu' shutdown: Timer too close (Ender 3 v3 SE)
The "dirty" Flag and the Team's Position
MCU shutdown with BTT CB1
What is the best way to have a live stream of the printer?
Klipper keep shutdown
Raspi shuts down mid print
[BUG] Klipper does not properly turn off heaters on host crash
Timer too close with MCU shutdown on almist every print
Problem with finding cause MCU shutdown Timer too close
"Timer Too Close" at a consistent time in file
Clipper shuts down when i send it home
MCU 'mcu' shutdown:
G28 Timer too close
Timer too close after moving to X out of range
MCU Shutdown Timer too close
Everything works except Heaters
CAN network failures - M8P CB2 EBB42
Timer too close only when print is finished
Is there a way to diagnose CAN cable?
Possible bug in G3 (arc) command
Klipper: "MCU 'mcu' shutdown: Timer too close"
Timer too close SB2040 Pro and Manta M8P V2.0
New Timer Too Close... Need Help
Timer too close after tool change - running happy hare (reproducible)
MCU 'mcu' shutdown: Timer too close when homing
Native canbus MCU 'EBBCan' shutdown: Timer too close
MCU 'EBBCan' shutdown: Timer too close This often indicates the host computer is overloaded
Timer to Close on TH0
EBBCan shutdown – Timer too close error
Mcu shutdown, timer too close. no usb manta m5p
MCU 'mcu' shutdown: Timer too close error ONLY when using OrcaSlicer
Twotrees SK1 spontaneously halts
Timer too close, multiple fans
Timer too close on ebb36
Printjob unexpectantly halted during night
EBB SB2209 CAN(RP2040)Speed
Manta M8P Timer too close
Timer too close and MCU shutdown
Timer too close shutdown on 1000mm+ moves
MCU 'mcu' shutdown:
Failed print due to following error message: Transition to shutdown state: Previous MCU 'mcu' shutdown: Timer too close
"MCU 'mcu' shutdown: Timer too close" when homing
Mcu shutdown: Timer too close
Sudden MCU Shutdown During Print
Klipper stops in middle of print
MCU 'mcu' shutdown: Timer too close - OctoEverywhere Triggered
MCU 'mcu' shutdown:
MCU 'mcu' shutdown:
MCU shutdown: Timer too close [SD card?]
Spontaneus stop during the print
Timer too Close on Voron 2.4
Help with identifying timer too close error cause
MCU shutdown on homing Z
Lost communication with MCU and MCU 'mcu' shutdown: Timer too close
MCU 'ercf' shutdown: Timer too close
