Thank you for starting a new thread here.
Going over your klippy.log, the first order of business is that your version of Klipper is “dirty”:
Starting Klippy...
Args: ['/home/mks/klipper/klippy/klippy.py', '/home/mks/printer_data/config/printer.cfg', '-I', '/home/mks/printer_data/comms/klippy.serial', '-l', '/home/mks/printer_data/logs/klippy.log', '-a', '/home/mks/printer_data/comms/klippy.sock']
Git version: 'v0.12.0-379-gf2e69a370-dirty'
The first order of business is to go to the “MACHINE” page in your Mainsail web page and do updates to get rid of the “dirty” status.
Then run again and see if the problem persists.
I should point out that this is a “Timer Too Close” error. If, after getting rid of the “dirty” status problems persist, then read through and look for situations that affect your printer:
