BTT Manta M8P Pi fan
Printer Model: Ender 5plus
MCU / Printerboard: BTT Manta M8P V1.1 with CB1
Describe your issue: I am trying to use the Pi fan port to power a fan for the CB1. This is the callout in printer cfg but I get this error “Unknown pin chip name ‘CB1’”.
[heater_fan SoC_fan]
pin: CB1:gpio79
#pin: RPI:gpio26
Thanks
klippy (3).log (81.0 KB)
You haven’t added the CB1 as a 2nd MCU. Or at least have not defined a [mcu CB1] in your printer config.
You need to flash Klipper (setup for Linux) to the CB1 (similar to how you flash Klipper to RPI for input shaper). Then define:
[mcu CB1]
serial: /tmp/klipper_host_mcu
Can’t confirm if the ‘gpio79’ is right or wrong…
Thanks
That worked. I would like to figure out how to have the fan turn on at a specific CB1 temperature. Right now it turns on with the hotend. I’ve called out the CB1 temp sensor.
[temperature_sensor CB1]
sensor_type: temperature_host
min_temp: 10
max_temp: 100
[temperature_sensor mcu_temp]
sensor_type: temperature_mcu
min_temp: 0
max_temp: 100
[fan]
pin: PE6
[heater_fan fan1]
pin: PE0
pin: CB1:gpio79
#pin: RPI:gpio26
Just to close the loop, I got the fan to work like I wanted using this:
[temperature_fan SoC_fan]
pin: CB1:gpio79
#pin: RPI:gpio26
kick_start_time: 0.8
off_below: 0.1
max_power: 1.0
control: pid
min_temp: 10
max_temp: 100
pid_kp: 1.0
pid_ki: 0.5
pid_kd: 2.0
min_speed: 0.1
max_speed: 0.8
target_temp: 38
One kind request I have:
Please always put your code snippets between code braces.
I makes reading more easy and spaces do not get lost:
Format
Got it … :+1:
Thanks
