Printer Model: Anycubic I3 Mega
MCU / Printerboard: BTT M5P Manta
klippy.log (69.6 KB)
…Unknown pin chip name ‘RPI’
I am new to this but BTT provides a good os image and I adjusted a file path name as it was different was the only thing I think could have broke the code
Please help
Hello @moneybags !
Have you setup the Pi as secondary mcu?
https://www.klipper3d.org/RPi_microcontroller.html#why-use-rpi-as-a-secondary-mcu
BTW: The [bltouch] section does not appear complete:
[bltouch]
sensor_pin = PC13
control_pin = PC15
It is a BTT manta m5p with the cbi board attactched to the board directly. I installed the OS frome the btt git hub. I will read up on the link.
the OS comes with mainsail and moon raker with some other stuff pre installed
The bltouch initiats when i turn the printer on
i read some thing that the directory was was mislabled as “host”
pin out for the M5P is PC13, GND,PC15,5V,GND I checked the wiring too.
could it be it is asking for rasberry pi when it should ask for CB1 the printer config example was provided throu klipper not BTT
Sineos
February 23, 2024, 6:04am
7
It seems you are trying to use a GPIO pin on your SBC to control a fan:
[heater_fan SoC_fan]
pin = RPI:gpio26
You have not defined the [mcu RPI] that would control this pin.
Refer to RPi microcontroller - Klipper documentation
You are aware that you cannot simply connect a fan to a GPIO pin without additional hardware and that this might even destroy your SBC?
moneybags:
You have no offsets?
The BLtouch is at the same position as the nozzle?
system
Closed
April 23, 2024, 7:39am
9
