BTT Pi Board Fan PG19 pin doesn't work
Printer Model: Ender 3
MCU / Printerboard: BTT E3 RRF
klippy.log klippy (2).log (4.0 MB)
I’ve connected fan on PG19 pin of the BTT Pi and Klipper doesn’t recognize them. Do you have a config to make it work?
error mainsail : Pin ‘PG19’ is not a valid pin name on mcu ‘mcu’
actually I’ve bypass with one pin on my board but I want to use PG19 pin on BTT PI
[temperature_fan raspberry_pi]
pin: PB6
kick_start_time: 0.8
#shutdown_speed: 0
off_below: 0.1
max_power: 1.0
#fan_speed: 0.6
sensor_type: temperature_host
control: pid
min_temp: -40
max_temp: 85
#max_delta: 5.0
pid_kp: 1.0
pid_ki: 0.5
pid_kd: 2.0
min_speed: 0.1
max_speed: 0.6
target_temp: 38
If i create and another MCU like this :
[mcu host]
serial: /tmp/klipper_host_mcu
And define :
pin: host:PG19
I’ve got message like this : Pin ‘PG19’ is not a valid pin name on mcu ‘host’
Thanks and hope we can solve this issue
Well, there is no PG19 pin! https://raw.githubusercontent.com/bigtreetech/BTT-E3-RRF/master/BTT%20E3%20RRF%20V1.1/Hardware/BTT%20E3%20RRF%20V1.1-SCH.pdf
Good luck, hcet14
PG19 pin is on BTT PI
thanks ^^
Can you provide the schematics?
So, what board do you have?
I guess I got it:
Printer mainboard:: BTT E3 RRF
SBC: BIGTREETECH Pi V1.2
@So6Rallye
wants to connect a fan to this PG19 (last picture)
that’s right, thanks for precision
You need to find out, how PG19 is connected to the H616 controller. But BTT doesn’t provide the schematics. You could ask BTT support.
I took the liberty to move the solution into the “Config” category for easier future reference.
Good job in finding and sharing this solution @So6Rallye :+1:
On the BTT Github for this board they have a section regarding the fan - BTT-Pi/BIGTREETECH Pi V1.2 - Board Fan Pin Configuration at master · So6Rallye/BTT-Pi · GitHub
Also follow this: RPi microcontroller - Klipper documentation (klipper3d.org)
Yep, it’s me, i’ve made pull request with the solutions on BTT github. look the end of your link " So6Rallye/BTT-Pi · GitHub" :upside_down_face:
