Having some trouble with variables
Printer Model: Ender 5 plus
MCU / Printerboard: BTT Manta M8P with BTT mini 12864
Describe your issue: I have setup and extra lights menu for changing colours for my BTT mini 12864. I wanted the selected colour to persist after shutdown so I save the colour variable. I am trying to setup some conditions at startup but my if syntax isn’t correct so the green macro runs even though the colour value is 2.
Any help would be appreciated:
Thanks
Set RGB values with macro on boot up.
Index 1 = display, Index 2 and 3 = Knob
[delayed_gcode setdisplayneopixel]
initial_duration: 1
{% set svv = printer.save_variables.variables %}
{% set colour = svv.colour %}
{% if colour != β€œ1” %}
M117 {colour}
green_light
{% elif colour != β€œ2” %}
M117 {colour}
red_light
[menu __main __lights]
type: list
[menu __main __lights __green]
type: command
SAVE_VARIABLE VARIABLE=colour VALUE={1}
	green_light
[menu __main __lights __red]
type: command
SAVE_VARIABLE VARIABLE=colour VALUE={2}
	red_light
[menu __main __lights __blue]
type: command
SAVE_VARIABLE VARIABLE=colour VALUE={3}
blue_light
[menu __main __lights __orange]
type: command
SAVE_VARIABLE VARIABLE=colour VALUE={4}
orange_light
[menu __main __lights __yellow]
type: command
SAVE_VARIABLE VARIABLE=colour VALUE={5}
yellow_light
[gcode_macro green_light]
SET_LED LED=btt_mini12864 RED=0 GREEN=1 BLUE=0 INDEX=1 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=0 GREEN=1 BLUE=0 INDEX=2 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=0 GREEN=1 BLUE=0 INDEX=3
[gcode_macro red_light]
SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=1 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=2 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=3
[gcode_macro blue_light]
SET_LED LED=btt_mini12864 RED=0 GREEN=0 BLUE=1 INDEX=1 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=0 GREEN=0 BLUE=1 INDEX=2 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=0 GREEN=0 BLUE=1 INDEX=3
[gcode_macro orange_light]
SET_LED LED=btt_mini12864 RED=1 GREEN=.6 BLUE=0 INDEX=1 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=1 GREEN=.6 BLUE=0 INDEX=2 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=1 GREEN=.6 BLUE=0 INDEX=3
[gcode_macro yellow_light]
SET_LED LED=btt_mini12864 RED=.98 GREEN=.93 BLUE=.65 INDEX=1 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=.98 GREEN=.93 BLUE=.65 INDEX=2 TRANSMIT=0
SET_LED LED=btt_mini12864 RED=.98 GREEN=.93 BLUE=.65 INDEX=3
[save_variables]
filename:~/variables.cfg
Please attach the klippy.log as a file to your next post
klippy.log (2.1 MB)
Klippy log attached
Of course:
	{% if colour != "1" %}
	M117 {colour}
	green_light
	{% elif colour != "2" %}
	M117 {colour}
	red_light
2 != 1 so the first comparison is true and green_light is called
What happens with svv.colour = 1 ?
when I select green from the menu and svv.colour is set to 1, the green_light executes and the display is green and M117 displays 1
I changed to this and neither macro runs - the display reverts to the initialize state below and svv.colour is not displayed:
{% if colour == β€œ1” %}
M117 {colour}
green_light
{% elif colour == β€œ2” %}
M117 {colour}
red_light
[neopixel btt_mini12864]
pin: EXP1_6
chain_count: 3
color_order: RGB
initial_RED: 0.4
initial_GREEN: 0.4
initial_BLUE: 0.4
Is it because you are comparing to a string, not an integer.
Thanks Eddy
That was the issue - works like a charm now!
