Two Z endstops plus probe with an IDEX printer
Printer Model: T-Rex 3
MCU / Printerboard: Vivedino 1.1
klippy.log (302.9 KB)
I like to run two regular endstops on my dual Z drive axes IDEX printer.
I connected the endstops to the GPIO of the raspi.
The BLTouch is mounted to [extruder] (the left one, in difference to [extruder1] on the right side)
I like to use the BLTouch to create the bed mesh.
I there a way to say Klipper that the BLtouch is mounted to [extruder] as it was formerly done by endstop_pin: probe:z_virtual_endstop in the [extruder] section.
It appears that Klipper assumes the BLTouch to be mounted to [extruder].
Everything works as expected.
