Getting Two Z_axes and one Endstop w/out Four Wires?
Printer Model: Maker Select Plus (Monoprice and discontinued)
MCU / Printerboard: A64 and STM/Recore A7
klippy.log (61.2 KB)
Am I allowed to use two wires, one endstop, and two Z_Axes w/ accompanying motors?
I do not want to use four wires or create another working endstop. Is it possible to use two wires, one endstop (mechanical), and two Z_Axes?
Seth
P.S. I will work on the klippy.log soon. Please forgive my tardiness. Okay, I added the klippy.log, made some additional ideas available, and am trying now to use Klipper to handle one endstop, two wires, two Z_Axis steppers for Z and Z1, and then make the UART available.
Update
I think this is a limitation if anything. No issue any longer. I think the idea of having stops for each, separate motor movement should be in place. Safety is a big thing in relation to things happening that are out of the beholder’s eye.
If you don’t want to use 2 endstops, then don’t define an enstop pin for stepper_z1. It’s not required.
Right @jakep_82 ,
Thank you. You are correct. In the [stepper_z1] header, I do not need the endstop pin(s) for the Klipper version I am using.
Thank you again.
Seth
Okay…
So, the dual Z_Axes w/ a motor for each axis seems to be disturbed. It is disturbed to the point that it crashes into the bed.
I can home XYZ but not the second Z_Axis motor.
  1. Do I need a second Endstop?
  2. Do I need to wire something differently?
Is there a way to port the second Z_Axis motor to understand and obey the first Z_Axis motor w/ the endstop?
Seth
If you use one, the x axes more parallel to the bed.
When you turn off the power, due to the weight of the X axes assembly, the Z height can change on both side differently. To be sure the X axes is parallel to the bed, you use an endstop at z1.
You need an endstop switch and a free input pin on your printer board. In addition Vcc and GND.
step_pin: ar100:PL6
dir_pin: !ar100:PE10
endstop_pin: ar100:PH6
rotation_distance: 2
position_endstop: 0.0
position_max: 177.0
homing_speed: 8.0
[stepper_z1]
step_pin: ar100:PL8
dir_pin: !ar100:PE12
So, this will not work…
The reason I am asking is b/c of the error in mechanics. It is like my source does not understand I have one endstop to handle both Z_Axis motors.
Seth
Update
So, I do need a second endstop but I cannot call it in the .cfg file. It tells me that it is an error.
It can work as long the X axes stays parallel to the bed.
Else you would need to run a [z_tilt] for what you need a probe. In that case you can directly home the Z axes with the probe.
Can you show me the code you try to use?
This is it:
step_pin: ar100:PL6
position_max: 177.0
homing_speed: 8.0
[stepper_z1]
step_pin: ar100:PL8
In [stepper_z1], I do not have access to putting in another stepper endstop…
Seth
No free pin on the printer board?
There are free pins available but when I put an endstop_pin: in [stepper_z1], I get errors.
It says as output, no endstop is available in [stepper_z1].
Seth
So please show the code you try to use:
Hello,
Okay. I was wrong. I am not sure how wrong I am so far but…
  1. The endstop for Z1 works but I cannot get both motors to work in tandem.
  2. I am working on the cfg file now.
Seth
P.S. I was just discussing the source in the cfg file, i.e. nothing more. I am sorry.
@EddyMI3D ,
Okay, you were right all along. I must have been mistaken early on. The two endstops work w/ the two Z_Axis motors along w/ homing. Phew…thank you.
So, instead of just homing and raising up the gantry for the two Z_axis motors…
I typed, BY ACCIDENT, G0 Z0 Z110 thinking I could control the second Z_stepper at Z1 w/ a G0 command. Oops…
Seth
P.S. Thank you again for your knowledge.
I learned it too, because on one of my printers I have the same setup with the Z axes.
