Printer Model: Ender 3 V2
klippy.log Can’t get this - see below
I just switched from a Pi 3B+ to a 4B 2GB. Klipper booted perfectly and Mainsail loaded perfectly (after changing my bookmark to the new Pi’s IP). I saw there was updates because I hadn’t run it in a month or so so I hit update. Now it’s stuck in a boot loop. The last line I see on the screen is “Klipper Login:” then it goes to a black screen with a cursor top left then back and forth. Mainsail won’t connect, can’t SSH in via IP (thus no klippy.log).
Any ideas? TIA
