Printer Model: Ender 3 v2
MCU / Printerboard: GD32F303
klippy.log (66.2 KB)
Fill out above information and in all cases attach your klippy.log
file. Pasting your printer.cfg
is not needed
About 3 days ago I started installing klipper in a old machine that I had laying around but when I got to flashing klipper it seems its not flashing. I tried switching between different SD cards (FAT32, 4096) but still wont flash (It is stuck on the creality logo screen not the blank that was supposed to) I can flash back to marlin and other firmware. I did follow trough the cfg for ender 3 v2 2020 (STM32F103, 28KiB bootloader, Selected disable SWD for Gigadevice clone, Extra low-level, USART3 PB11/PB10, 250000 baudrate, and changed the .bin file name between flash tries). After that I though it could be that the mcu was just not connecting to Linux, so I followed along another post and disabled modemmanager and brittly. Now it outputs the the path when using ls /dev/serial/by-id/* our by-path (both works) but still saying that it cant connect to the mcu (tried connecting with marlin flashed and it cant recognize the mcu)
Edit: Here it is the dmesg output
[ 4762.240136] usb 2-1: new full-speed USB device number 3 using uhci_hcd
[ 4762.424219] usb 2-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 4762.424245] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4762.424257] usb 2-1: Product: USB Serial
[ 4762.427945] ch341 2-1:1.0: ch341-uart converter detected
[ 4762.441529] usb 2-1: ch341-uart converter now attached to ttyUSB0
