Printer Model: Ender 6 (core x,y)
MCU / Printerboard:BTT Manta M8P
klippy(7).log (1.6 MB)
This is a new build that is yet to print anything. Everything homes correctly, the bed mesh seems to be working. I have set the Z offset (and saved it) but whenever I try to print the nozzle just scores accross the print bed. I have measured the Z axis travel and seems accurate so the rotational distance is correct for the lead screw. I’m completely at a loss as to what my issue is.
[EDIT] One thing I have noticed is that when homed the dashboard shows a toolhead Z distance of 10, but the actual distance from nozzle tip to bed is closer to 5mm.
Any help would be gratefully appreciated.
