What does this error message mean?
Printer Model: vcore 31
MCU / Printerboard:octopus pro + ebb42
I am trying to set up new Zprobe…
When i do ztilt, the printer starts making the passes until the tolerance is set below the set limits.
But when he gets it, an error message comes out, qie I do not understand what he means or why he jumps at the end, when he has managed to adjust the ztilt
Bed Distance Sensor, out of range.:3.90
// Retries: 0/10 Probed points range: 0.015938 tolerance: 0.020000
// Making the following Z adjustments:
// stepper_z = 1.035855
// stepper_z1 = 1.016634
// stepper_z2 = 1.014598
// probe at 360.000,60.000 is z=1.017031
// probe at 235.000,370.000 is z=1.017031
// probe at 60.000,60.000 is z=1.032969
$ Z_TILT_ADJUST
The error:
BED DISTANCE SENSOR OUT OF RANGE;3.90
Formated in red.
Sensor its a Panda Pi Bdsensor, according to the data sheet, it has a sense distance of 4mm
klippy.log (7).txt (520.6 KB)
As requested, please post klippy.log
This type is not officially supported in Klipper. Please open your case here: GitHub - markniu/Bed_Distance_sensor: Auto bed level with High resolution distance sensor
