Basic Information: Looking for a slicer(Klipper integration) that is dedicated to liquid deposition modeling.
Printer Model: modified RatRig 400
MCU / Printerboard: BTT Octopus 1.1
Describe your issue: Looking for an open source slicer (Klipper integration) that is dedicated to LDM- liquid deposition modeling. FDM slicer’s don’t have some of the controls or settings needed for paste or silicone extrusion. For example, the luer lock syringe tip we use has an ID of .016". There are no slicer’s that allow custom nozzle sizes? Another, the extrusion layer is not "squished’ onto the previous layer. It needs to print so it bridges on top of the previous layer. Most of the structures are this pseudo rectilinear lattice with a perimeter. I need the slicer to act like it is in “vase” mode, only print the infill also. Ideally this would continue with as few start and stop points in the layers as possible. There are other needs but you get the idea. Any info is much appreciated. Thanks!
