Difficulties with bringup on STM32G431
Been attempting to compile and load Klipper on an STM32G431 microcontroller (specifically, a prototype board that I naively assumed would work with no issues, like my previous experience with the F407). However, upon compiling and flashing the firmware with DFU over USB, the board subsequently is not recognized as a USB device.
To my knowledge, it appears that there have been no prior attempts to run Klipper on a G4 despite it being a supported architecture, so I’m not ruling out the possibility that this is an issue with the Klipper stm32g4 code. Will attempt to diagnose this issue further. I’ve included the terminal output when flashing below:
Flashing out/klipper.bin to 0483:df11
sudo dfu-util -d ,0483:df11 -R -a 0 -s 0x8000000:leave -D out/klipper.bin
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 1024
DfuSe interface name: "Internal Flash   "
Downloading to address = 0x08000000, size = 26360
Download	[=========================] 100%        26360 bytes
Download done.
File downloaded successfully
dfu-util: Error during download get_status
Failed to flash to 0483:df11: Error running dfu-util
If the device is already in bootloader mode it can be flashed with the
following command:
  make flash FLASH_DEVICE=0483:df11
  OR
  make flash FLASH_DEVICE=1209:beba
If attempting to flash via 3.3V serial, then use:
  make serialflash FLASH_DEVICE=0483:df11
make: *** [src/stm32/Makefile:111: flash] Error 255
