Voron 2.4 R2 300.
Octopus V1.1
klippy.log (3.8 MB)
When click on Attach Probe Macro I get the following error.
Move out of range: -942.000 300.000 25.000 [0.000].
Thanks in advance for your help.
You need to configure the variables for dock and endstop location. It appears you simply copied the files and didn’t configure anything.
Wrong answer given. I config the dock and end stop locations. The write answer I got from the facebook group. I had to config Variable_dockmove_x: and ariable_attachmove_y: both under Dock move, final toolhead movement to release the probe on the dock
#it’s a relative move and Attach move. final toolhead movement to attach the probe on the mount
#it’s a relative move. Respectively.
Thanks anyway.
