Need a little help with variables. Is there a way to check what the current state of a variable is over console? It seems like dooropen is not getting set back to 0 when the door is shut even down the macros are running.
Attached is a door_switch.cfg with code to work with a door safety switch. Everything works except when it’s time to resume the print, it just keeps running door_open_state2.
[gcode_macro RESUME]
description: Resume the actual running print
rename_existing: RESUME_BASE
{% if dooropen == 0 %} # check to see if door is open - requires [virtual_sdcard]
G28 X
G28 Y
##### read extrude from _TOOLHEAD_PARK_PAUSE_CANCEL macro #####
{% set extrude = printer[‘gcode_macro _TOOLHEAD_PARK_PAUSE_CANCEL’].extrude %}
#### get VELOCITY parameter if specified ####
{% if ‘VELOCITY’ in params|upper %}
{% set get_params = (‘VELOCITY=’ + params.VELOCITY) %}
{%else %}
{% set get_params = “” %}
##### end of definitions #####
{% if printer.extruder.can_extrude|lower == ‘true’ %}
M83
G1 E{extrude} F2100
{% if printer.gcode_move.absolute_extrude |lower == ‘true’ %} M82 {% endif %}
{% else %}
{action_respond_info(“Extruder not hot enough”)}
RESUME_BASE {get_params}
{% else %}
door_open_state2
Thanks for the info but not really. I can already check the gcode_button state. It’s not setting dooropen to 0 when the door is shut but the rest of the release code runs.
[gcode_macro door_open_state1]
variable_dooropen: 0
{% if dooropen == 0 %} # requires [virtual_sdcard]
PAUSE # call printer pause macro
SIREN
M118 CLOSE DOOR THEN PRESS RESUME
{% else %}
SIREN
UPDATE_DELAYED_GCODE ID=set_dooropenbusy DURATION=2.5 # timing must be set to clear delay plus 0.5s.
Yes, I sent that before corrected but even after changing the second one to state2, still does not work.
I’ve narrowed it down to the resume macro not reading the state of the variable. I need a work around and I’m thinking about using an open output pin as a dummy just to be able to use the pin state.
get_door_open
[gcode_macro get_door_open]
G28 X
G28 Y
{%else %}
M83
G1 E{extrude} F2100
{% else %}
{% else %}
door_open_state2
Maybe something like this. But no warranty whatsoever.
@Sineos thanks! That still results in it running the else statement in both pin states. @koconnor how can we use a gcode button variable as a dependency?
IT WORKS! I just wish there was an alternative so object naming was door switch instead of filament runout since there is also a filament runout sensor in there for logging purposes.
{% if printer[“filament_switch_sensor door_closed”].filament_detected == True %}
G28 X
G28 Y
{%else %}
M83
G1 E{extrude} F2100
{% else %}
{% else %}
door_open_pause
