Printer Model: Ender 3
MCU / Printerboard: BTT SKR Mini E3 -v- 3.0
Host / Raspberry Pi 4B, 2GB
klippy.log (13.5 KB)
I’m installing an LDO Nitehawk 36, mainly to reduct the amount of wiring running to the hot end. It uses the USB bus for data and commands, which is a much simpler setup than CANbus. The toolhead has an integrated accelerometer (adxl345), so that takes care of the X-axis, but I still need to cover the Y axis.
I’m planning to install a second ADXL345 on the bed (permanently, using only when needed), connected to a Raspberry Pi PICO board, and connecting the PICO to the Pi 4. Unless that’s unnecessary and/or overkill, and I should wire the second ADXL345 directly to the Pi 4 using the GPIO header?
My question is: since the USB bus is already handling the X-axis adxl345, can I still use the USB bus to connect the PICO to the Pi 4 (and will Klipper be able to keep the two straight {and/or what needs to go into the config file to enable this?}), OR should I keep the two separate (if this is needed) by connecting the PICO to the Pi 4 using the GPIO header pins?
If anyone could steer me towards a good writeup of what’s needed to do this (or answer it here), I’d very much appreciate it!
