I cannot configure two independent drivers for two z axes with relative mechanical endstops in each axis. I make the home but at the end of the race it makes the second home only on the z axis and not also z1
Solved, it was the socket of the octopus that did not reverse the movement, moved the socket the tmc2209 works correctly. Thanks
