Dudes about bed mesh
I have been reading the information on the web, and I have two questions:
  • When you make a bed mesh… You have to do something (a start gcode in the slicer, some option in Mainsail, in my case,…) for the print to use that bed mesh. Maybe start gcode (bed_mesh_profile_load=default)
  • If in a print you do not want to use the bed mesh. How would it be done? Bed_mesh_clear in start gcode or by console
  • I must assume, that if the bed mesh is seen in the web interface (in my case Mainsail) is being used, if they were not being used nothing will appear.
  • Mesh_fade options, must be setup in config.cfg? Or can be configured in start gcode or real time by console?
i do have the same question
