Best strategy for load bed mesh?
Printer Model: Ratrig Vcore 3
MCU / Printerboard:Octopus pro + EBB42
klippy.log, not necessary
Not an issue…
what is the best strategy to use the Bed Mesh…
I’m currently using Fluidd, and even though I’ve made the bedmesh… it doesn’t screw up by default. And I wanted to know which workflow is the most suitable:
  • Option 1: That the BED MESH be loaded as soon as the printer is turned on.
  • Option 2: That the BED MESH is loaded after doing BED TILT
  • Option 3: Make it load only when printing starts, adding it to START GCODE…
Once the BED MESH is loaded, does it affect all the movements made by the printer? or will it only apply to the print job only?
What would be the procedure in each of the three Options?
  • First Homing
  • Then Bed Tilt (I do Gantry Tilt instead)
  • Then load Bed Mesh.
  • Then start print
BTW: How many points does the mesh have?
The bed is 400x400 and I haved 7x7 points.
In the start print macro, include bed mesh load. No?
Include in the START PRINT MACRO
BED_MESH_CLEAR
BED_MESH_PROFILE LOAD=
Yes, but after G28 and no G28 after the BED_MESH_LOAD
Will this achieve the same effect as Marlin’s UBL Tilt?
