Bed_mesh_level at start of print without save/restart
Printer Model: Artillery Sidewinder X1
MCU / Printerboard: SKR 1.4 Turbo
Hi there. General, possibly stupid, question. I have not found any answers anywhere else (except ChatGPT, but I don’t trust robots I can’t send a G28 command to).
When I do a bed_mesh_calibrate, at the end Klipper/Mainsail always prompts me to save the profile and restart. How do I do a bed mesh level (G29 equivalent) with every print as part of my start_print macro without restarting Klipper?
This is more Mainsail than Klipper.
You can just insert BED_MESH_CALIBRATE into the start gcode and you are good to go. In that case, you use that gcode instead of BED_MESH_PROFILE Load=mesh1
When you have a huge bed with more than 3x3 test points, it is more convenient to do the mesh once in a while, save it and reload it when it is used.
With a 5x5 mesh, you have to consicer, if you went to do the mesh before every print.
You may also see here:
https://www.klipper3d.org/Bed_Mesh.html
Thanks for the reply. So seems more mainsail and klipperscreen. Any suggestions on how to prevent those prompts from coming up? Klipperscreen in particular is annoying as gives a wholescreen prompt with “continue” or “restart”.
Take a look at GitHub - kyleisah/Klipper-Adaptive-Meshing-Purging: A unique leveling solution for Klipper-enabled 3D printers!
Thank you! Seems like my Google skills are terrible, given that I’ve been looking for this answer off and on for a few days now.
What’s interesting is that when I set my BED_MESH_CALIBRATE profile=default this prompt doesn’t happen. I’ll double check though to make sure I’m not imagining it.
-S
