First time bed mesh on mainsail/klipper
Printer Model: ender 3 pro
MCU / Printerboard:BTT skr mini v3
Host / SBC pi 4 model b
the configs i listed below are currently working. i was able to get a fir map in. but im not sure if its correct or not. i did level the bed before getting that map down Preformatted text# This file contains common pin mappings for the.
# E3 v3.0. To use this config, the firmware should be compiled for the
# STM32G0B1 with a "8KiB bootloader" and USB communication.
# The "make flash" command does not work on the SKR mini E3. Instead,
# after running "make", copy the generated "out/klipper.bin" file to a
# file named "firmware.bin" on an SD card and then restart the SKR
# mini E3 with that SD card.
[include mainsail.cfg]
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
rotation_distance: 40
endstop_pin: ^PC0
position_endstop: 0
position_max: 230
homing_speed: 50
[tmc2209 stepper_x]
uart_pin: PC11
tx_pin: PC10
uart_address: 0
run_current: 0.580
stealthchop_threshold: 999999
[stepper_y]
step_pin: !PB10
dir_pin: !PB2
enable_pin: !PB11
endstop_pin: ^PC1
position_endstop: 0
position_max: 230
homing_speed: 50
[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
uart_address: 2
run_current: 0.580
step_pin: PB0
dir_pin: PC5
enable_pin: !PB1
rotation_distance: 8
position_max: 250
position_min: 0
[bltouch]
sensor_pin: ^PC14
control_pin: PA1
## Offset for Hero Me 6
x_offset: -60
y_offset: -30
z_offset:  1.700 # Uncomment if starting fresh; Distance should be enough to keep the z-offset positive.
speed: 3.0
samples: 2
samples_result: median
sample_retract_dist: 6.0
samples_tolerance: 0.02
samples_tolerance_retries: 5
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 35, 5
mesh_max:160,160 # Make sure X,Y here meets these conditions (X+(bltouch+x_offset) < bed X) and (Y+(bltouch+y_offset) < Bed Y)
probe_count: 5,5
fade_start: 1
fade_end: 10
[screws_tilt_adjust]
screw1: 32,36
screw1_name: front_left
screw2: 32,206
screw2_name: front_right
screw3: 202,206
screw3_name: back_left
screw4: 202,36
screw4_name: back_right
# Additional bed leveling screws. At least two screws must be
# defined.
speed: 50
screw_thread: CW-M3
[input_shaper]
shaper_freq_x: 20.576  # frequency for the X mark of the test model
shaper_freq_y: 35.821  # frequency for the Y mark of the test model
shaper_type: mzv
[safe_z_home]
home_xy_position: 115.00, 115.00 # Change coordinates to the center of your print bed
speed: 50
z_hop: 5                 # Move up 10mm
z_hop_speed: 5
[tmc2209 stepper_z]
uart_pin: PC11
tx_pin: PC10
uart_address: 1
run_current: 0.580
step_pin: PB3
dir_pin: !PB4
enable_pin: !PD1
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC8
sensor_pin: PA0
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 250
[tmc2209 extruder]
uart_pin: PC11
tx_pin: PC10
uart_address: 3
run_current: 0.650
[heater_bed]
heater_pin: PC9
sensor_pin: PC4
control: pid
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[heater_fan heatbreak_cooling_fan]
pin: PC7
[heater_fan controller_fan]
pin: PB15
[fan]
pin: PC6
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_290007000550414235363020-if00
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
[board_pins]
aliases:
    # EXP1 header
    EXP1_1=PB5,  EXP1_3=PA9,   EXP1_5=PA10, EXP1_7=PB8, EXP1_9=<GND>,
    EXP1_2=PA15, EXP1_4=<RST>, EXP1_6=PB9,  EXP1_8=PD6, EXP1_10=<5V>
# See the sample-lcd.cfg file for definitions of common LCD displays.
type or paste code here
i have pei build plate 235x235
Please attach the klippy.log to your next post.
Upload
my klippy file size is too large to send its 10mb and im only allowed to send 8mb or lower
Have you read this? That part in the part between the brackets?
klippy (11).log (5.2 MB)
