wrang
September 21, 2024, 9:05am
1
Printer Model: Ender 3pro
MCU / Printerboard: BIGTREETECH SKR V1.4
Host / SBC: Pi 3B+
klippy.log (30.4 KB)
Hello. totally new to this so hoping for help. If there is something missing, let me know.
my ebb 42 1.2 complains about double pinout and I don’t know how to solve this. Have this code in an ebb43.cfg file it complains about PB 8, PB9 that they are double for bltouch and probe.
Sineos
September 21, 2024, 9:15am
3
What probe are you using? Why do you need the [output_pin probe_enable] setting?
wrang
September 21, 2024, 9:21am
4
Thanks for the quick help. I use the BIQU MicroProbe V2.0
I don’t know why with this [output_pin probe_enable] got help from a friend.
Do you have a suggestion how everything could look like?
Sineos
September 21, 2024, 9:25am
5
Sineos
September 21, 2024, 9:27am
6
Or rather not wrong but you have a surplus
[bltouch]
sensor_pin = ^EBBCan:PB3
control_pin = EBBCan:PB9
z_offset = 1.360
in your config. Delete it and it should work, given the pin assignments are correct for the EBB (didn’t check)
wrang
September 21, 2024, 9:35am
7
I tried changing to pin PB3 then it came up that it had double PB9
the probe is connected to ebb 42 so not directly to the motherboard so the link to the settings i cand find right now
Sineos
September 21, 2024, 9:47am
8
Again, delete the entire bltouch block. It is wrong when you use the MicroProbe
wrang
September 21, 2024, 9:50am
9
have tested. this it becomes Klipper reports: ERROR
Option ‘control_pin’ in section ‘bltouch’ must be specified
wrang
September 21, 2024, 9:51am
10
this is what i find about
Pinout EBB42 v1.1 & v1.2
Sineos
September 21, 2024, 10:05am
11
Post a fresh klippy.log
In general, post a new log whenever you change something and encounter an issue,
wrang
September 21, 2024, 10:10am
12
klippy (1).log (202.0 KB)
here is a fresh one
klippy (2).log (217.6 KB)
Sineos
September 21, 2024, 11:04am
13
[gcode_macro Probe_Deploy]
SET_PIN PIN=probe_enable VALUE=1
[gcode_macro Probe_Stow]
SET_PIN PIN=probe_enable VALUE=0
pin: EBBCan:PB9
value: 0
[probe]
pin: !EBBCan:PB8 # <<<<<<<<<<<<<<<<< CHANGE
deactivate_on_each_sample: False
x_offset: -42.0
y_offset: -8.0
z_offset: 5
speed: 5.0
samples: 2
samples_tolerance: 0.05
samples_tolerance_retries: 3
activate_gcode:
Probe_Deploy
G4 P500
deactivate_gcode:
Probe_Stow
wrang
September 21, 2024, 11:10am
14
klippy.log (373.5 KB)
I have deleted [bltouch] as you write but it still says that it is still in the log file
Sineos
September 21, 2024, 11:13am
15
Go to your printer.cfg file and find
Below this line you will see another [bltouch] section with the respective z-offset. Delete the entire section.
wrang
September 21, 2024, 11:18am
16
wow thank you very much now I have no errors.
removed the ones you suggested in printer.cfg and everything started without error
respect! Sineos
Now I’ll just run all the other calibration functions
