"Unknown pin chip name 'probe'"
So I’m trying to set up my ender 3 with klipper using an skr 2 (because apparantly I need to rewire the screen to get it to work so screw that). Upon setting up the config things for the fake BLtouch I get this:
I have found like 4 other posts on the internet of people having the same problem and it magically fixing itself or something, so I have no clue what’s wrong. If anyone knows or sees something that can help please let me know :smiley:
klippy.log (381.2 KB)
printer (1).cfg (5.7 KB)
Hello @ginowup !
If you use probe:
step_pin: PA15
dir_pin: PA8
enable_pin: !PD1
rotation_distance: 40.2010050251
endstop_pin: probe:z_virtual_endstop  ;<----
#endstop_pin: ^PC0
#position_endstop: 0.5
position_max: 300
You have to use a probe like BLtouch or similar.
Else you have to set the z endstop switch pin here.
I’m not sure what you mean because I am using a BLtouch clone
Maybe, but there is no BLtouch section in the printer.cfg.
https://www.klipper3d.org/Config_Reference.html#bed-probing-hardware
https://www.klipper3d.org/Config_Reference.html#bltouch
https://www.klipper3d.org/BLTouch.html
did you even read the config file? it is litterally the second section
Section headers are case sensitive. You have [BLtouch]. Needs to be [bltouch]
oooooh thank you so much!
Sorry, I’ve overseen it.
I usually put it after the stepper sections.
fair enough, it happens thanks for taking a look anyway!
