Klipper unable to start Ender 3 Max
Cant start klipper all i get is message Unknown pin chip name ‘probe’ I’m using Ender 3 max with bltouch connected to its dedicated port. If i try to define Probe i get Unable to parse option ‘position_max’ in section ‘stepper_z’ error. But in all examples i was looking for printer with bltouch noone needed to define probe
# This file contains pin mappings for the stock 2020 Creality Ender 3
# MAX. To use this config, during "make menuconfig" select the
# STM32F103 with a "28KiB bootloader" and serial (on USART1 PA10/PA9)
# communication.
# Because this printer has factory wiring, mounts, and firmware for
# a BLTouch, but does not ship with one at this time, default values
# for the sensor have been specified, but disabled, in anticipation of
# future revisions or user modification. User should take care to
# customize the offsets, particularly z-offset, for their specific unit.
# If you prefer a direct serial connection, in "make menuconfig"
# select "Enable extra low-level configuration options" and select
# serial (on USART3 PB11/PB10), which is broken out on the 10 pin IDC
# cable used for the LCD module as follows:
# 3: Tx, 4: Rx, 9: GND, 10: VCC
# Flash this firmware by copying "out/klipper.bin" to a SD card and
# turning on the printer with the card inserted. The firmware
# filename must end in ".bin" and must not match the last filename
# that was flashed.
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: 0
position_max: 300
homing_speed: 50
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
endstop_pin: ^PA6
position_endstop: 0
position_max: 300
homing_speed: 50
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
rotation_distance: 8
#position_endstop: 0.0                     # disable to use BLTouch
#endstop_pin: ^PA7                         # disable to use BLTouch
endstop_pin: probe:z_virtual_endstop    # enable to use BLTouch
position_min: -5                        # enable to use BLTouch
position_max: 340
 [safe_z_home]                         # enable for BLTouch
 home_xy_position: 150, 150
 speed: 100
 z_hop: 10
 z_hop_speed: 5
 [bltouch]                             # enable for BLTouch - fast-mode
 sensor_pin: ^PB1
 control_pin: PB0
 pin_up_touch_mode_reports_triggered: True
 #probe_with_touch_mode: True
 x_offset: 50                          # modify as needed for bltouch location
 y_offset: -6                          # modify as needed for bltouch location
 z_offset: 0.0                         # modify as needed for bltouch or run PROBE_CALIBRATE
 speed: 10
 #samples: 3
 #sample_retract_dist: 5.0              # Can be set lower, example 2.5 depending on height of bltouch from bed
 #lift_speed: 40
 #samples_tolerance_retries: 3
 #speed: 10
 #samples: 2
 [bed_mesh]                            # enable for BLTouch
 speed: 300
 mesh_min: 50, 0
 mesh_max: 290, 290
 algorithm: bicubic
 probe_count: 7,7                      # 49 points due to large bed size
 horizontal_move_z: 5
 [gcode_macro G29]                    # If moving from marlin to klipper uncomment to mimic G29
  BED_MESH_CALIBRATE
  G1 X0 Y0 Z10 F4000
max_extrude_only_distance: 100.0
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
rotation_distance: 31.901           # Calibrate - see https://www.klipper3d.org/Rotation_Distance.html
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 250
pressure_advance: 0.0               # Calibrate - see https://www.klipper3d.org/Pressure_Advance.html
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
control: pid
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[fan]
pin: PA0
[filament_switch_sensor e0_sensor]
switch_pin: PA4
serial: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0    # Run ls /dev/serial/by-id/* for micro-controller name
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
[display]
lcd_type: st7920
cs_pin: PB12
sclk_pin: PB13
sid_pin: PB15
encoder_pins: ^PB14, ^PB10
click_pin: ^!PB2
probe defined like this
[probe]
pin: ^PB1
z_offset: -1
i dont have any idea what im doing
Hello @D3moz !
You have an additional space in front of some settings.
You may delete them.
Really, only that, i was hitting my head to a wall for few hours only for some spaces…
Thx that helped
Thank you so much, I’d missed this last night when trying out Klipper for the first time, started over today and I was doing the same thing, leaving the leading spaces. Still don’t have a clue what I’m doing but at least those error messages have stopped :slight_smile:
