Printer Model: Voron 2.4/350 LDO kit (many homebrew mods), under construction
MCU / Printerboard: Pi 4 / Octopus 1.1 / EBB36
This is NOT an issue ! At most a feature request.
Searched about the EBB36 ADXL345 orientation, and the influence on the accelerations. Found nothing interesting…
The EBB36 is oriented at 45° (43 to 46 or so, depending on the gears adjustments - measured in CAD). Meaning that X accelerations will influence both X and Y MEMs, and Z accelerations are read by both as well. Shouldn’t have any effect on the IS recommandations. And it doesn’t. I compared with the readings from a ADXL345 attached to the hotend cardridge.
The x+y+z curves are very similar. For the individual curves (x, y and z), the result is not the same (it was expected)
Was expecting x test with readings on x and z, both being equal ; verified
No effect on the resonance frequency (obviously)
Was expecting some 0.707 (sqr(2)/2, sin(45°)) relation between the PSD peaks ; it is there
EBB36 onboard ADXL345 (I just reaffected z to y, the two others are defaults) :
The results with the accelerometer attached where it is supposed to be on a Stealthburner :
Somewhere, there was a FR for an option in calibrate_shaper.py so we could enter an angle, and recalculate the real X and Z from the rotated readings… (maybe on Github)
For the input shaper tuning, it is of no interest. But could it be interesting for results analysis, mechanical diagnosis, and belt tensioning for example ? (I have no knowledge, just starting to learn from some videos on YT)
Also quickly read calibrate_shaper.py ; unfortunately not familiar with Python (C/C++ only, for decades). It is simple math (vector rotations)… But can’t see where I could do the math… Also could preprocess the csv file in Excel… Could it be of any interest ? (rarely use Excel, but I think it could be easier)
