EBB36 for Toolhead and TMC5160
CoreXY
Manta M8P V2
CB2
TMC5160 2xX, 2xY
TMC2209 2xZ
EBB36
klippy(5).log (323.9 KB)
I flashed the EBB36 and connected it. I created the config for the Ebb36 and inlcuded it in my printer config. Since then, i’m getting the following error message: Pin ‘PC13’ is not a valid pin name on mcu ‘mcu’. As i read, the TMC5160 isn’t compatible with the EBB36, so i guess i have to somehow seperate them.
You are probably using the wrong example cfg file.
There are three versions of the EBB36 and each has a few pins resigned.
